Register to reply
Laplace Eq. Cylinder and 3D Heat Equation
by splitringtail
Tags: cylinder, equation, heat, laplace
Share this thread:
splitringtail
#1
Oct20-08, 12:21 AM
P: 59
Sorry, it does not seem that Latex is not compiling my code right so I will try my best to be clear.
The curved surface of a cylinder of radius a is grounded while the end caps at z = L/2 are
maintained at opposite potentials ψ (r,θ, L/2)= V(r,θ).
Suppose that a simple solid brick with uniform initial temperature
is immersed at time t = 0 in a heat bath. The temperature ψ (r,t) within the material
satisfies
∂ψ = ∇^2 ψ
k∂t
with ψ(r,0)=T1 and ψ(at surface,t)=T2
I really just want to clear up some interpretations.
2. Relevant equations
Laplaican for Cylindrical and Rectangular Coordinates.
3. The attempt at a solution
I want to assume that grounded means the potential at the curved surface is zero, but I cannot find it in my notes or book or even online. After that it's just putting it in the equation, I have to solve both exterior and interior cases, nothing new.
The second question is really confusing me in choosing the appropriate separation constants. Now we solved the 3-D Laplace equation in rectangular coordinates. The separation constants I choose were
a^2 b^2 c^2 = 0 this implies that a^2 = b^2 + c^2
this gives you a sin/cos solutions in two directions and a sinh/cosh in one solution one direction. I choose the sinh/cosh solution for the direction w/ the non-homogeneous boundary, which you repeat six times to get a complete solution. Now for the question given, I want to choose
a^2 b^2 c^2 d= 0 this implies that
d= a^2 b^2 c^2
so, all my solutions are in the sin/cos form except T??
We have T' + k (d) T = 0, since a,b,c are > 0 (other cases are trivial solutions), then d < 0 and k > 0, so I can have an exp(), solution.
I was really wanting a way to work in a sinh/cosh solution, so that I could use what I got from the previous homework, but I guess it is just a little modification. I guess that makes since b/c it is some form of a wave equation. It seems non-intuitive to me.
Phys.Org News Partner Science news on Phys.org
Fungus deadly to AIDS patients found to grow on trees
Canola genome sequence reveals evolutionary 'love triangle'
Scientists uncover clues to role of magnetism in iron-based superconductors
Register to reply
Related Discussions
Heat exchanged to air on a cylinder problem? Introductory Physics Homework 2
Heat Transfer Through a Cylinder Engineering, Comp Sci, & Technology Homework 1
Heat removed from a gas in a cylinder Introductory Physics Homework 1
S.E in cylinder - Bessel's equation Introductory Physics Homework 5
Grounded conducting cylinder using Laplace Introductory Physics Homework 5
