Determining the static and kinetic coefficients on an incline of wood on wood
The discussion focuses on determining the static and kinetic coefficients of friction for a block of wood on a wooden plank. The static coefficient was calculated using the angle of 45.4 degrees, yielding a value of 1, which is unexpectedly high for polished wood surfaces. For the kinetic coefficient, the block was released from a height of 50 degrees, covering a distance of 1 meter in 0.69 seconds. The participant seeks guidance on calculating the kinetic coefficient and understanding the relationship between time, distance, velocity, and acceleration using kinematic equations.
  • Understanding of basic physics concepts, specifically friction and motion.
  • Familiarity with kinematic equations and their applications.
  • Knowledge of how to measure angles and time accurately in experiments.
  • Ability to perform calculations involving trigonometric functions, such as tangent.
  • Learn how to apply kinematic equations to calculate acceleration and velocity.
  • Research the standard coefficients of friction for wood on wood to compare results.
  • Explore methods for accurately measuring time and distance in physics experiments.
  • Investigate the effects of surface finish on the coefficient of friction for wood materials.
Students in physics or engineering courses, educators teaching mechanics, and anyone conducting experiments related to friction and motion in materials science.
cmcc3119
This was a lab task in which we are asked: Determine the static and dynamic coefficients of friction for a block of wood of mass 82.2grams on a plank of wood.
PART A:
To determine the static coefficient we found the angle at which point the block just started to move. This was 45.4 degrees.
For Part A, I used the equation fr = tan 45.5 degrees which gave me an answer of 1. I am not sure if this is to be expected static coefficient of a polished block of wood on a plank of wood as anything else I have read has always had a lower coefficient.
PART B:
To determine the kinetic coefficient we increased the angle to 50 degrees and timed how long the block took to cover the plank, a distance of 1 meter, when released from the top. The average time was found to be 0.69s. This is where I get stuck! I do not know how to calculate the kinetic coefficient and after much research on the net I am still as stuck as I first was... The block is accelerating but I don't know how to determine the acceleration or whether that is even necessary. Furthermore, can I just state the velocity is 0.69ms-1?
Can someone please just suggest a starting point...
Try the kinematic equations, they're the ones that relate time, distance, velocity and acceleration when the acceleration is constant.
  • · Replies 16 ·
  • · Replies 28 ·
9K
