Finding the Spring Constant of a ball
The problem involves a spring mechanism launching a ball horizontally, with the goal of determining the spring constant based on the ball's trajectory and the parameters of its motion. The subject area includes mechanics, specifically the concepts of energy conservation and projectile motion.
  • Mixed
  • Participants discuss the initial conditions of the problem, including the mass of the ball and the compression of the spring. There is an exploration of calculating the initial velocity of the ball based on the time it takes to fall a certain vertical distance. Some participants question the motion of the ball in both horizontal and vertical directions, considering the effects of gravity.
Some guidance has been offered regarding the steps to find the initial velocity and the relationship between kinetic energy and potential energy in the spring. Multiple interpretations of the problem are being explored, particularly concerning the components of motion.
Participants express confusion about the calculations involved and the relationship between the horizontal and vertical motions of the ball. There is an acknowledgment of the complexity of the problem as it involves both energy considerations and projectile motion.
ckrup
1. A spring clamped to a table shoots a 20 g ball horizontally. When the spring is compressed 18 cm the ball travels horizontally 5.1 m and lands on the floor 1.7 m below the point at which it left the spring. What is the spring constant (in N/m)
2. I tried using k=mg/x (x being distance of the spring compression) but am at a COMPLETE loss as how to solve it!
Welcome to PF.
This is a double problem.
First find the initial velocity, which is totally in the x direction.
You do that by figuring the time for it to drop 1.7 m.
Take that time and determine horizontal velocity by 5.1 m / Time to drop.
Now for part 2:
You know the V so you know KE which is mV2/2
If you know KE then you know how much PE was initrially in the spring by PE = k*x2/2
You know x, you know PE now you can finally know k.
i have a similar problem to this one and am stuck. Isn't the ball moving in the y direction also since it falls below where it left the spring?
Welcome to PF.
Yes. Gravity does develop a y component of velocity. But the x component only is the initial velocity and it is this velocity that determines how far from the table it lands.
The Vx * t is that distance. Hence the importance of calculating the t in order to determine that distance.
  • · Replies 17 ·
