Differentiation & composite functions
The discussion revolves around the interpretation of the notation for differentiation of composite functions, specifically the meaning of df[g(x)]/dx and its equivalence to other notations. Participants explore the implications of different approaches to differentiation, including the chain rule and potential inconsistencies in notation.
  • One participant questions whether df[g(x)]/dx implies differentiating f with respect to x first or evaluating f at g(x) before differentiating.
  • Another participant introduces the chain rule, stating that the two methods described by the first participant are equivalent.
  • A participant provides an example using specific functions to illustrate the application of the chain rule and the resulting derivative.
  • Concerns are raised about the notation df[g(x)]/dx yielding inconsistent results compared to other forms, leading to confusion about the interpretations of the notations.
  • One participant expresses a preference against using certain notations due to perceived inconsistencies in results.
Participants express differing views on the clarity and consistency of the notation for differentiation of composite functions. There is no consensus on the preferred notation or its implications, as some participants find the notations lead to different interpretations and results.
Participants highlight potential limitations in understanding due to the ambiguity of notation and the dependence on interpretations of the differentiation process.
kingwinner
What is the actual meaning of the notation of
Code:
df[g(x)]
  dx
Here do we actually differentiate f with respect to x first and then evaluate it at g(x), or do we first evaluate f at g(x), then differentiate it with respect to x? Does the order matter?
df
--[g(x)]
dx
d
--f[g(x)]
dx
Are these two equivalent to the first one? (i.e. do all three notations have exactly the same meaning?)
Thanks for explaining!
Have you learned the chain rule yet?
Let
f = f(g)
g = g(x)
h = f(g(x))
Then the chain rule is precisely the statement that
[tex]\frac{dh}{dx} = \left. \frac{df}{dg} \right|_{g(x)} \; \frac{dg}{dx}[/tex]
In other words, the chain rule states that yes, your two methods described are equivalent.
What d f(g(x))/dx really means is that you take the composite function: first apply g to x then apply f to that. Whatever function you get is what you differentiate.
For example, if g(x)= 3x- 4 and f(x)= x2, then f(g(x))= (3x-4)2= 9x2- 24x+ 16. The derivative of that is 18x- 24.
As has been pointed out, you could also use the "chain rule". Letting u= g(x), f(g(x)) becomes f(u) and the chain rule says df(g(x))/dx= (df(u)/du)(du/dx)= (df(u)/du)(dg/dx).
Since f(u)= u2, df(u)/du= 2u and since g(x)= 3x- 4, dg/dx= 3.
(df(u)/du)(du/dx)= (2u)(3)= 6u= 6(3x-4)= 18x- 24 as before.
But the following notation seems to give inconsistent results:
df
--[g(x)]
dx
In your example,
df
--(x) = df/dx = 2x (df/dx is a function of x)
dx
df
--[g(x)] = 2(3x-4) = 6x-8 (evaluate the derivative function at g(x) )
dx
which is different from 18x - 24
So this is what I am concerning with, there are 3 notations (see top post) that seemingly represent the same thing, but can get different answers because their interpretations can be different...
Please help...this is what I've been wondering (and having trouble understanding) for a long time...and the 3 different ways of writing a derivative as shown in the first post come up very often.
df
--[g(x)]
dx
Yes, that notation does. That's why I would never use such notation!
In your example,
df
dx
df
dx
And I did not write any of those things. That is why I do not use that notation.
