backpack on a line
by itryphysics
Tags: backpack, line
itryphysics
itryphysics is offline
#1
Oct25-08, 07:45 PM
P: 114
The two trees in the figure are 6.9m apart. A back-packer is trying to lift his pack out of the reach of bears. (a)Calculate the magnitude of the force F that he must exert downward to hold a 15 kg- backpack so that the rope sags at its midpoint by 1.5m . (b)Calculate the magnitude of the force that he must exert downward to hold a 15 kg- backpack so that the rope sags at its midpoint by 0.16m .
2. Relevant equations
3. The attempt at a solution
Distance between the trees =6.6 m
Half of distance between the trees = b =6.9/2= 3.45 m
sag at mid point = a = 1.5 m
Consider the vertical right anglled triangle with ' b ' as base, ' a ' as height and the half portion of rope as hypotenues ' h '
The hypotenues = h = sq rt [ b^2 + a^2 ] ,
h = sq rt [ 3.45^2 +1.5^2 ]
h =3.762 m
Now the hypotenues ( h = 3.762 m ) represents force Fand side 'a' represents weight 98 N
F/h =(15kg*9.8)/a
F /3.762 =147 /1.5 m
F =368.7 N
This is answer is not right. I dont know what im doing wrong :S Please guide me
Phys.Org News Partner Science news on Phys.org
SensaBubble: It's a bubble, but not as we know it (w/ video)
The hemihelix: Scientists discover a new shape using rubber bands (w/ video)
Microbes provide insights into evolution of human language
Mark44
Mark44 is offline
#2
Oct25-08, 08:40 PM
Mentor
P: 21,071
Quote Quote by itryphysics View Post
h =3.762 m
So far, so good.
[QUOTE=itryphysics;1929899]
[quote]
The weight is wrong. The mass of the pack is 15 kg, so its weight is 15 * 9.8 = 147 N. Your later work seems to use the right value.
F/h =(15kg*9.8)/a
F =368.7 N
I get the same answer you did. My reasoning is that the right triangle has sides 1.5 m and 3.45 m. and hypotenuse ~3.76m. The length of the short leg of the triangle has to be in the same ratio to the downward force as the hypotenuse length is to the force along the rope. IOW 1.5/15 = 3.76/F, or F = 37.6 (in kg) (I'm not really dealing with forces just yet, just mass. Converting the number I got for F to a force, I multiplied by 9.8, and got 368.7 N (rounded).
You said you didn't think this was correct. What's the answer you believe is correct?
Register to reply
Related Discussions
line that intersects and is perpendicular to another line Calculus & Beyond Homework 1
Find the equation of the normal line of the given parabola that is parallel to a line Calculus & Beyond Homework 9
equation of line parallel to plane and intersaction with other line Precalculus Mathematics Homework 5
Asteroid Collision Course and Sagging Backpack Introductory Physics Homework 6
Bicycle "Jet" Backpack General Discussion 7
