Help with using the Squeeze Theorem to find a limit.
  • Thread starter Thread starter pzzldstudent
    Limit Theorem
The discussion revolves around applying the Squeeze Theorem to find the limit as n → ∞ of the sequence {(2^n + 3^n)^(1/n)}. Participants explore the concept of bounding the sequence with functions A and B that converge to the same limit.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants discuss potential bounding functions and the use of the Binomial theorem. Some express uncertainty about using the Squeeze Theorem and suggest alternative methods, such as taking logarithms. Questions arise about how to properly apply limits and the implications of their chosen approaches.
The discussion is ongoing, with various approaches being suggested. Some participants have offered guidance on bounding the sequence, while others are questioning the appropriateness of the Squeeze Theorem for this problem. There is a mix of interpretations and attempts to clarify the application of limits.
Some participants note that they have not yet covered the Binomial theorem in their coursework, which may limit their ability to apply certain methods. Additionally, there is a mention of confusion regarding the placement of the nth root in their comparisons.
pzzldstudent
We were given the hint to try using the Squeeze Theorem in order to find the
I understand the concept of the squeeze theorem that I need to find functions A and B such that A ≤ {(2^n + 3^n)^(1/n)} ≤ B, and A and B limit to the same quantity, say "L."
So lim A = lim B = L, so that I can conclude that lim (2^n + 3^n)^(1/n) = L.
I don't know how to come up with those functions. It has been 2 years since I last took a calculus class, so I am very rusty with limits.
So far all I have is that 0 ≤ {(2^n + 3^n)^(1/n)} ≤ 2^n + 3^n.
So I can say 0 limits to 0, but then how would I evaluate
the limit of 2^n + 3^n as n approaches ∞? It would just keep getting bigger so I would have that limit as ∞. So I am stuck with 0 and ∞ as limits which is wrong because A and B are supposed to limit to the same value.
Any help, tips, corrections, and/or suggestions is greatly appreciated.
Thank you for your time!
To find A and B, you might try using the Binomial theorem on [itex](2^n+3^n)^{\frac{1}{n}}=3\left(1+\left(\frac{2}{3}\right)^n \right)^{\frac{1}{n}}[/itex]...Clearly, [itex]\left(1+\left(\frac{2}{3}\right)^n\right)^{\frac{1}{n}} \geq 1[/itex] can you think of a function that is always greater than or equal to this quantity and also has a limit of 1?
I'm not sure I'd use the squeeze theorem on this. But if you want to, 3^n<=2^n+3^n<=3^n+3^n.
I think the binomial theorem is just plain overkill. If you want to do it that way, then just take the log of the second factor and look at the limit. BTW that's how I would have done it without using 'squeeze'.
Thanks for looking at this thread. We haven't gotten to the Binomial Theorem yet, and I don't think our professor will be emphasizing it that much, so I think that if I use that theorem, it would appear unrealistic for me to do that since we haven't covered it yet.
Thanks for the input though, and I'll definitely look into the binomial theorem a bit more when our professor mentions it.
Dick said:
I'm not sure I'd use the squeeze theorem on this. But if you want to, [tex]3^{n}[/tex] [tex]\leq[/tex] [tex]{2^{n}+3^{n}}[/tex] [tex]\leq[/tex] [tex]3^{n}[/tex] + [tex]3^{n}[/tex].
Will this work?
3 [tex]\leq\sqrt[n]{2^{n}+3^{n}}[/tex] [tex]\leq[/tex] 3[tex]\sqrt[n]{2}[/tex]
How do I know the limit of 3[tex]\sqrt[n]{2}[/tex] is 3?
So is the limit of [tex]3^{n}[/tex] = 3 = limit of [tex]3^{n}[/tex] + [tex]3^{n}[/tex].
But I am taking [tex]\sqrt[n]{2^{n}+3^{n}}[/tex] and not just [tex]{2^{n}+3^{n}}[/tex]
To figure out the lim (2)^(1/n), take the log. The limit if the log is pretty clear, isn't it?
I've forgotten how to take logs and limits of logs.
Is it
log 2^(1/n) can be rewritten as (1/n) = [tex]log_{2}[/tex] x?
How do I find the limit from there? Take ln?
Is it
In (1/n)=log_2(x) do you mean x=2^(1/n)?
If you want to try and sneak around the logs, 2^n+3^n<=3^n+3^n+3^n=3*3^n=3^(n+1).
Where's the radical?
I'm still not quite "seeing" it. Where does the radical 'nth root' go?
I understand the comparison of 2^n+3^n<=3^n+3^n+3^n=3*3^n=3^(n+1), but I'm still struggling with how to relate it to the problem that has [tex](2^{n} + 3^{n})^{1/n}[/tex]. Where are you putting the (1/n) exponent in the comparison?
(3^n)^(1/n)=3<=(2^n+3^n)^(1/n)<=(3^(n+1))^(1/n)=3^(1+1/n).
Cool, thanks a lot! I think I got it now. If not, I'll post again here. Thanks for all your help thus far!
