Can Term by Term Integration Give a Wrong Answer for Integrable Functions?
  • Context: Graduate
  • Thread starter Thread starter elfboy
    Function
The discussion centers on the validity of term by term integration for integrable functions, specifically addressing the conditions under which it may yield incorrect results. It is established that if a function is integrable and all steps in the integration process are executed correctly, the resulting integral value must be accurate. However, term by term integration of an infinite series may lead to erroneous outcomes unless the series converges uniformly. The discussion highlights that uniform convergence is essential for the validity of term by term integration over finite intervals.
  • Understanding of integrable functions
  • Knowledge of uniform convergence in series
  • Familiarity with term by term integration techniques
  • Concept of improper integrals
  • Study the criteria for uniform convergence of series
  • Learn about the properties of integrable functions in real analysis
  • Explore the implications of improper integrals in calculus
  • Investigate examples of term by term integration and their convergence behavior
Mathematicians, calculus students, and educators seeking to deepen their understanding of integration techniques and the conditions affecting the accuracy of integral evaluations.
elfboy
to be integratable but still give a wrong answer even if all the steps are performed correctly? Assume that an infinite series is equal to some integral. Then you evaluate the integral between two values. Beforehand, you ensure that the series converges for those two endpoints. But the resulting answer is wrong even though the steps are correct.
NO, if a function is integrable, and you follow all of the steps involved in finding that integral correctly, you must get the correct value of the integral. However, finding the integral of an infinite sum by integrating term by term and then taking the limit may NOT be "performing the steps correctly"! That's your real question isn't it?
If the series converges uniformly then term by term integration is valid. There is a special situation: if a series of functions converges, then it converges uniformly in any compact (for sets of real number- closed and bounded) set. Since a finite interval, [a, b], is both closed and bounded, you can always integrate a series term by term from a to b as long as both a and b are finite. For an improper integral that may not be true.
