How Does Light's Wave Nature Affect Double Slit Experiment Results?
The double slit experiment with slit separation of 2.0mm and wavelengths of 750nm and 900nm demonstrates that the first bright fringe from one pattern coincides with the other at a distance of 0.0045m (or 4.5mm) from the central maximum on the screen. The correct approach involves equating the fringe equations for both wavelengths, leading to the relationship m = (λ2/λ1)n, where m and n are the orders of the fringes. The calculations confirm that for m=6 and n=5, the fringes align at this specific distance.
  • Understanding of wave interference principles
  • Familiarity with the double slit experiment setup
  • Knowledge of fringe order and its significance in interference patterns
  • Basic trigonometry and algebra for solving equations
  • Study the mathematical derivation of the double slit experiment equations
  • Learn about wave interference and diffraction patterns in physics
  • Explore the impact of varying slit separations on fringe patterns
  • Investigate the effects of different wavelengths on interference results
Physics students, educators, and anyone interested in wave mechanics and optical experiments will benefit from this discussion.
Dx
Hello,
In a double slit experiment the slit separation is 2.0mm and two wavelengths 750nm and 900nm illuminate the slits. A screen placed 2m from the slits. at what distance from the central maximum on the screen will a bright fringe from one pattern first conincide with a bright fringe from the other?
my formula?
d = sin[the] / (m [lamb]
Is my answer correct 6.0mm
Thanks!
Dx :wink:
d=2E-3meters, λ1=750E-9m, λ2=900E-9m, D=2m (D being adjacent leg of right triangle, y1 and y2 being opposite legs, θ being angle between slits.)
y1 = mλ1D / d = (1)(750E-9m)(2m)/(2E-3)m = 7.5E-4m
y2 = nλ2D / d = (1)(900E-9m)(2m)/(2E-3)m = 9.0E-4m
were n=m=1, WHICH THEY're not.
You can't solve it trigonometrically.
In order to solve it, you need to equate
y1=y2=mλ1D/d = nλ2D/d
Then you just solve for m:
m = (λ2/λ1)n = 1.2n
The first instance of this relation being true is if m=6 and n=5
Now you just solve y1 and y2 above to get...
y1=y2=0.0045m
Hello Dx,
Your answer is not quite correct. The formula you provided is the correct one to use, however, the value for "m" should be the same for both wavelengths since we are looking for the first bright fringe that coincides for both patterns. The value for "m" represents the order of the fringe, with m=0 being the central maximum. So, for the first bright fringe to coincide, we need to solve for m=1 for both wavelengths.
Using the given values, we get:
d = sin[the] / (m [lamb])
For 750nm:
d = sin[the] / (1 x 750nm)
d = sin[the] / 750nm
For 900nm:
d = sin[the] / (1 x 900nm)
d = sin[the] / 900nm
Since we are looking for the same distance, we can set these two equations equal to each other and solve for d:
sin[the] / 750nm = sin[the] / 900nm
Cross-multiplying and solving for d, we get:
d = (750nm x 900nm) / 750nm
d = 900nm
Therefore, the first bright fringe from one pattern will coincide with the first bright fringe from the other at a distance of 900nm from the central maximum on the screen.
I hope this helps clarify things. Keep up the good work!
11K
