Rotating bicycle wheel question
  • Context: Undergrad
  • Thread starter Thread starter fluidistic
    Bicycle Rotating Wheel
The discussion revolves around the behavior of a rotating bicycle wheel when attempting to change its orientation from vertical to horizontal. Participants explore concepts related to torque, angular momentum, and the effects of applied forces on the wheel's motion. The scope includes conceptual understanding and technical reasoning in physics.
  • One participant questions the direction of force needed to change the orientation of the wheel, noting that a helper-teacher suggested applying force "down" but expressing confusion about the implications of this advice.
  • Another participant suggests that applying torque perpendicular to the wheel's axis is necessary, indicating that the response of the wheel will be out of phase with the applied torque.
  • A later reply acknowledges a misunderstanding about the wheel's ability to maintain its vertical plane and position in space, clarifying that it will fall while conserving its vertical orientation until it reaches the ground.
  • Some participants propose that significant torque may be required to change the wheel's orientation, and that compensatory movements may be necessary.
Participants express varying levels of understanding regarding the mechanics of the rotating wheel, with some confusion about the application of force versus torque. There is no clear consensus on the best approach to changing the wheel's orientation or the implications of high rotational speeds.
Participants mention the need to read more about torque and force couples, indicating that there may be gaps in understanding the underlying principles. The discussion includes assumptions about the wheel's behavior that are not fully resolved.
fluidistic
Hey,
Today I assisted to a lecture I didn't understand in Physics I.
I've asked to a helper-teacher a question and he made me much more confused.
Say I have a rotating bicycle wheel in my hands (my hands don't influence the wheel's rotation) in front of me such that the wheel is in a vertical plane only. If I want to change the plane from the vertical to the horizontal, in what direction must I apply a force on the wheel? The helper told me "down". I said OK and left the class. While I was leaving I was completely mixed up. Does that mean that if the wheel rotates at say 10000 Hz, I wouldn't be able to inclinate it from vertical to horizontal, even if the wheel is in the air and that I put all my weight on it? It would inclinate a very bit and at last it would fall off the floor. But this implies that the wheel can get stuck in the air for a while if it rotates at a high angular speed and in a vertical plane. Is that true? I just can't believe it!
fluidistic said:
Hey,
Hey fluidistic! :smile:
(assister? mais non, "assist" means "help" … you attended a lecture :wink:)
You can turn the wheel … but it may need a lot of force (torque) … and you may have to rotate yourself ("do a cartwheel") to compensate. :smile:
See http://64.233.183.104/search?q=cache:p6LO2TP0SXYJ:www.arborsci.com/Data_Sheets/P3-3505_DS.pdf+torque+%2B+%22bicycle+wheel%22&hl=en&ct=clnk&cd=7&client=safari
You need to applied torque perpendicular to the axis, not a force, with the response being 90 degrees out of phase with the torque you apply. In this case you need to apply a yawing torque (turning around while holding the wheel will do the trick), and it will respond with a roll reaction.
Thanks both for your replies.
When I turned off the computer yesterday I realized I was wrong in something : I thought that the wheel would preserve its vertical plane but also its position in space which is untrue. Of course if I let the wheel fall off it will fall and not stay in the air as I thought. But I understand now that it will fall conserving its vertical plane and when it will reach the floor it will begin to roll.
I'm getting the concept, but I must read more on this. Especially on couple (torque?).
Go to the Wikipedia pages on force couple and also torque.
  • · Replies 22 ·
  • · Replies 17 ·
  • · Replies 28 ·
  • · Replies 19 ·
  • · Replies 21 ·
