How do I approach resistors 7-9 and 10-12 in a resistor network?
  • Thread starter Thread starter Sanctam
    Network Resistor
The discussion revolves around a resistor network problem, specifically focusing on the approach to understanding the behavior of resistors 7 through 9 and 10 through 12. The original poster has made progress using a bus diagram but is uncertain about these specific resistors and how to analyze the currents at certain nodes.
  • The original poster considers the equalization of resistors 7 and 8, as well as 10 and 11, and questions how to find the currents at nodes E and D. Some participants suggest that resistors 7 through 12 may be shorted, leading to no current or voltage difference across them.
The discussion is ongoing, with participants exploring different interpretations of the resistor network. Some guidance has been offered regarding the behavior of the resistors, but no consensus has been reached on the approach to solving the problem.
The original poster mentions that this is early in their study of resistors, indicating a potential lack of familiarity with the concepts involved in analyzing such networks.
Sanctam
So I got this homework to do, and I've pretty much figured it all out using a bus diagram, except for one part. I don't know how to approach Resistors 7 through 9 and 10 through 12. The only idea that I have is that they equalize between 7 and 8, and 10 and 11.
This is the only idea I have as far as a bus diagram:
One last thing: Just a check on how to find the currents at E and D: Do I just add up all the currents traveling along each separate loop?
Ohm's Law: V=IR
I do not know where to begin
Welcome to PF.
First of all let me say that problem looks inhumane.
As to your interest in R7 R8 R9 and R10 R11 R12 isn't that a short across the bunch of them? So no current, no voltage difference for any of them, as all the nodes in that part of the network would measure as 24v wouldn't they?
As to your currents the sum of the currents entering a node are the same as those exiting ... but I will have to leave the numbers for you to work out.
Thank you so much! I can definitely do the numbers, I was just wondering about the concept. And it is inhumane, this is only like our 3rd day working with resistors!
  • · Replies 31 ·
