Solving 2nd Derivative Rule: f"(x)=-3(x^2+3)/(x^2-9)^3
  • Context: Undergrad
  • Thread starter Thread starter Megz27
    Derivative
The discussion revolves around the application of the second derivative rule to analyze the concavity of a function defined by the second derivative f''(x) = -3(x^2 + 3)/(x^2 - 9)^3. Participants explore how to determine intervals of concavity and the implications of the second derivative being zero or undefined.
  • One participant suggests that to find concavity, one should set f''(x) = 0, leading to the equation x^2 + 3 = 0, which does not yield real solutions.
  • Another participant points out that the numerator of f''(x) is always negative, indicating that f''(x) is never zero for real x, but is undefined at x = -3 and x = 3.
  • It is noted that the behavior of f''(x) on the intervals (-∞, -3) and (-3, 3) suggests that the graph is concave down on the first interval and concave up on the second interval.
  • One participant questions the necessity of finding x when f''(x) = 0 to prove concavity, suggesting that the sign of f''(x) is more critical.
  • Another participant elaborates that f''(x) being undefined can also indicate a change in concavity, emphasizing the importance of checking the sign of f'' around points of discontinuity.
Participants express differing views on the necessity of finding points where f''(x) = 0 to determine concavity. There is no consensus on the best approach to analyze the concavity of the function.
Participants highlight that f''(x) being zero does not guarantee a change in concavity, as it may represent a local extremum rather than a point of inflection.
Megz27
so to find when a graph is concave up or down you can use the 2nd derivative rule, but what happends if we have f"(x) = -3(x^2 +3)/(X^2-9)^3
what I am thinking is that we are looking for f"(x)=0 so x^2+3= O but that would give us x=(-3)^1/2...
any thoughts?
Your numerator is always negative, so f''(x) is never 0 (for real x). It is undefined at the points -3 and 3. If we look at the denominator, we see that on the open interval (-oo, -3), the change in the first derivative is negative and decreases without bound, while on the open interval (-3, 3) the change in the first derivative is positive and increases without bound. As the first derivative corresponds to the slopes of tangent lines to the graph, you can see why on the interval (-oo, -3) the graph is concave down while on the second interval, the graph is concave up (Start with an arbitrary tangent line and rotate it along a curve in the direction the second derivative gives).
Try to find the behavior of the graph of f as x decreases or increases without bound and on the third interval (3, oo).
how can we prove that tho? Cause wouldn't you have to find what x is when f '' (x) = O?
f''(x) is the derivative of the function f'(x), and thus inherits all the theorems about studying the behavior of f using f' (In this case we are studying the behavior of f' using f'').
As to finding when f''(x) = 0, that is only one way in which we can find where the sign of f'' changes. Another way the sign of f'' can change is if f''(x) is undefined when the sign changes, as f'' may not have removable discontinuities at these points. The sign of f''(x) is all we are concerned about when it comes to concave up or down. Note that f''(x) = 0 does not necessarily mean that the sign of f'' has changed; it may just be a minimum or maximum point for f'' so you still have to check the sign of f'' on both sides of that point. Ie., If f(x) = x6, then f''(0) = 0, but the graph never changes concavity. It is just "very flat" in the neighborhood of 0.
thanks
  • · Replies 17 ·
  • · Replies 19 ·
