Thread Closed
Mechanics: Eccentric torsion + non circular tube
Share Thread
Nov4-08, 08:58 AM   #1
dear all, i have just received a question about torsion.
*************** a graph has been attached as attachment at bottom*************
The objective is to find the torsion shear stress at the cross section of the "dark Grey tube".
Let's have a look:
1.There is a reaction torque acting on the motor M,
2.The force is then transfered to dark grey tube by a light grey carrier.
3. blue cross is the center of the motor
4. purple cross is the centroid of the dark grey tube
5. i have J / Ixx,Iyy of that tube
6. Only the dark grey tube is fixed at 2 ends.
7. carrier is mush shorter than the tube
2. Relevant equations
I think I am finding the suitable eqts. So I miss this section.
Or
You think T/J= shear/R ??
3. The attempt at a solution
So,
#1 i would like to ask whether the following steps are correct
and
#2 What is the torsion equations for irregular hollow section.
#3 how to find the R, outer radius of the shaft, for the case that equation T/J= shear/R is used.
My Methodology:
1. Shear force is acting at the 2 hand sides of the tube as resultant.
2. the Shear force acts like a torque on the hollow section
3. use parallel axis theorem to transform "moment of inertia" from the original centroid to the torque center
4. use a torsion equation that contain J to fix it (<------------#2 that's what i would like to find now)
Thank you very much for your help.
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Thread Closed
Similar discussions for: Mechanics: Eccentric torsion + non circular tube
Thread Forum Replies
Fixed-Tube-Sheet Shell and tube Heat Exchanger Materials & Chemical Engineering 1
Fluid Mechanics - U-tube and mercury Introductory Physics Homework 1
(Mechanics) A Plank in a Circular Trough Introductory Physics Homework 8
mechanics - mass on a circular ramp Introductory Physics Homework 2
Fluid Mechanics - Pressure - U-Tube Manometer Introductory Physics Homework 14
