| Thread Closed |
Solenoid with a magnetic core |
Share Thread | Thread Tools |
| Nov9-08, 07:39 PM | #1 |
A long solenoid with 70.0 turns of wire per centimeter carries a current of 0.100 A. The wire that makes up the solenoid is wrapped around a solid core of silicon steel (Km=5200). (The wire of the solenoid is jacketed with an insulator so that none of the current flows into the core.) For a point inside the core, find the magnitude of the magnetic field B due to the solenoid current. 2. Relevant equations 3. The attempt at a solution I used the regular solenoid equation B = munaught(n)I but i replaced munaught with munaught*5200 this gave me 4.55 but that isn't the right answer? |
| PhysOrg.com |
science news on PhysOrg.com >> Hong Kong launches first electric taxis >> Morocco to harness the wind in energy hunt >> Galaxy's Ring of Fire |
| Nov10-08, 12:52 PM | #2 |
Recognitions:
I get the same answer.
BTW, no need to double post. This is the correct forum for this question. |
| Dec30-09, 05:25 PM | #3 |
Hi:
How can I generate max magnetic field from 2" x 4" core surface? Any material can isolate magnetic field? Regards, Eugene |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Solenoid with a magnetic core
| Core material selection for high-current DC solenoid | Electrical Engineering | 7 | ||
| Magnetic core | Electrical Engineering | 5 | ||
| Solenoid Electromagnet with strong core, low residual magnetism | Electrical Engineering | 11 | ||
| solenoid core material | Materials & Chemical Engineering | 2 | ||
| solenoid core material | Electrical Engineering | 5 | ||
