Deriving EM Wave Equations from Faraday's & Ampere-Maxwell's Laws
The discussion revolves around deriving the electromagnetic wave equations from Faraday's law of induction and the Ampere-Maxwell law. Participants explore the implications of these laws in both vacuum and general media, focusing on the role of constants such as permittivity and permeability, as well as the behavior of charge flow in different contexts.
  • One participant expresses confusion about the disappearance of the factor 1/c² in their derivation and questions the behavior of the curl of charge flow.
  • Another participant suggests that the wave equation is typically derived under the assumption of no currents, as waves can propagate away from their sources.
  • There is a discussion about the constants μ and ε in Faraday's law, with some participants questioning why they do not appear in the form of the law being used.
  • Several participants clarify that in a vacuum, both charge density and current density are zero, which leads to the curl of charge flow being zero.
  • One participant seeks to understand the implications of assuming zero charge flow in a medium and how this affects the generality of the derivation.
  • Another participant mentions that the relationship between electric and magnetic fields in Faraday's law does not include constants due to dimensional considerations.
  • References to intermediate-level E&M textbooks and online lecture notes are provided for further exploration of the topic.
Participants generally agree on the definitions of vacuum and the implications for charge and current densities. However, there is ongoing debate regarding the treatment of charge flow in media and the presence of constants in Faraday's law, indicating that multiple competing views remain.
Participants note that deriving the wave equation in a vacuum assumes no free charges or currents, while in media, the behavior of the electric and magnetic fields may differ due to the presence of material properties. The discussion also highlights the complexity of electromagnetic theory and the need for careful consideration of definitions and assumptions.
TheFerruccio
I am trying to derive the electromagnetic wave equations from Faraday's law of Induction, and the Ampere-Maxwell law.
But, I am having a problem with the 1/c^2 disappearing.
This is what I am using:
[tex]\nabla\times\vec{B}=\mu\vec{J}+\mu\epsilon\stackrel{\partial\vec{E}}{\partial t}[/tex]
Taking the cross product of both sides, I eventually end up with...
[tex]\nabla (\nabla\cdot\vec{B}) - \nabla^{2} (\vec{B}) = \mu\nabla\times\vec{J}+\mu\epsilon\stackrel{\partial(\nabla\times\vec{E})}{\partial t}[/tex]
Divergence of B is 0, so that goes away.
I'm stuck, though, when it comes to the curl of the charge flow. I know that the charge flow is as follows:
[tex]\vec{J}=\sigma\vec{E}[/tex]
Does the curl of the charge flow vanish? Faraday's law of Induction would imply that I'd be taking the curl of the negative time rate of change of the magnetic field. I'd ideally like to see the curl of the charge flow disappear, unless something else appears when talking about the charge flow through a medium. I understand that space is essentially non-conductive, and if you are deriving these equations in the vacuum of space, you won't have a charge flow. I'd like to not make that assumption, though, and it would be great if I ended up with an extremely generalized form of the wave equation, which could show the speed of light as being different through different media.
Why doesn't mu and epsilon show up in Faraday's law of Induction? I'd imagine that the relationship between the Displacement field and Magnetization field would still end up producing constants. And, if it does, then I'm in big trouble, because my 1/c^2 disappears due to the [tex]\mu\epsilon[/tex] canceling out with the [tex]\mu\epsilon[/tex] in the curl of Ampere-Maxwell's law.
Maybe after more discussion, I can clear my mind a bit on why I'm hung up on this concept.
There can be a current in "empty space" (not really, by definition, but you know what I mean). The most common form of the wave equation is derived assuming no currents since a wave can travel far from the charges that caused it.
The speed of light in materials is different because the permittivity/permeabilities/dielectric constants are different from vacuum. Also in materials some sort of spatially avergaed field is considered, since the true microscopic field is very inhomogeneous and unknown.
So, what does the curl of the charge flow reduce to in this case?
Also, why aren't there constants [tex]\mu\epsilon[/tex] in Faraday's law?
Does anyone have any idea what my error in thought is?
I basically want to know where the constants in Faraday's law are, and what the curl of a charge flow is.
In classical electrodynamics, "in vacuum" means a region devoid of all charges...so, the charge density and the current density are both zero in vacuum.
Assuming you are deriving the wave equation in a vacuum, then Faraday's Law is actually in terms of the permittivity [itex]\epsilon_0[/itex] and permeability of free space [itex]\mu_o[/itex]:
[tex] \nabla \times \vec{B} =\mu_0 \vec{J}+\mu_0 \epsilon_0 \frac{\partial \vec{E}}{\partial t}[/tex]
When deriving the wave equation in a general medium on the other hand, you need to use Faraday's Law in terms of the Auxiliary and displacement fields instead:
[tex] \nabla\times\vec{H}=\vec{J_f}+ \frac{\partial \vec{D}}{\partial t}[/tex]
In this case, all that matters is that there is no free charge or free current inside the medium, so that [itex]\vec{J}_f=0[/itex]
In either case, when taking the curl of zero you naturally get zero!
That's Ampere's circuital law with the Maxwell correction, relating the induced magnetomotive force to the charge flux and electric flux. I understand how this law works, but I still don't quite understand why the curl of the charge flow is 0. You're saying that the charge flow represents free charges? How do you know that there is no free charge flow through the medium?
I can assume it's zero and deriving the EM wave equation becomes easy, but I'm still not sold on why J is 0, plus it wouldn't be a generalized proof. For instance, how would it be 0 if there is indeed charge flow inside the medium?
Additionally, once J is 0, I still end up with trying to convince myself why there are no constants in Faraday's law, which directly relates the electric field to the magnetic field, without any sort of scaling.
[tex]\nabla\times\vector{E}=-\frac{\partial \vec{B}}{\partial t}[/tex]
If D = epsilon*E, and B = mu*H, then why isn't Faraday's law actually...
[tex]\nabla\times\vector{E}=-\mu\epsilon\frac{\partial \vec{B}}{\partial t}[/tex]?
What you're looking for looks like it's discussed in most intermediate-level E&M textbooks, under the subject of "Electromagnetic Waves in Conductors." Two examples that I have on my bookshelf are Griffiths (section 9.4) and Pollak & Stump (section 13.3).
I don't want to try to reproduce their derivations here because I'm not familiar with this topic myself, so I'm not in a good position to answer questions about it. Do you have a library nearby?
[added] I just remembered a set of online lecture notes which includes this topic:
http://farside.ph.utexas.edu/teaching/em/lectures/node102.html
It's the dimensions …
E has the same dimensions as cB
and ∂/∂t has the same dimensions as c∇
So [tex]\nabla \times \vec{B} =\mu_0 \vec{J}+\mu_0 \epsilon_0 \frac{\partial \vec{E}}{\partial t}[/tex]
but [tex]\nabla\times\vector{E}\ =\ -\frac{\partial \vec{B}}{\partial t}[/tex] :smile:
