Register to reply
Equation w/ Homogeneous Coefficients - y=ux substitution
Share this thread:
ZachN
#1
Nov12-08, 12:20 PM
P: 24
I am teaching myself, this problem is from ODEs by Tenenbaum and Pollard. This is not homework for a class.
(x+y){dx} - (x-y){dy} = 0
2. Relevant equations
y=ux, {dy} = u{dx} + x{du}
3. The attempt at a solution
Substitution should lead to a separable equation in x and u:
(x+ux){dx} + (ux - x)(u{dx} + x{du}) = 0;
x(u+1)dx + u2x{dx} + ux2{du} - ux{dx} - x2{du} = 0;
xu(2){dx} + x2(u - 1){du} = 0;
-1/x{dx} = (u - 1)/(u2 + 1){du}
Okay, I am assuming that I am correct up to this point but the answer given by the text is:
Arc tan(y/x) - 1/2log(x2 + y2) = c
I understand where the Arc tan(y/x) comes from - the (1/(u2 + 1)). I am having trouble with the 1/2 log(x2 + y2) - where does the -log(x) go?
I have a couple of other problems in the same form as this which arise in isogonal trajectories and I don't want to just skip over this because I am obviously having a problem with these integrations.
Phys.Org News Partner Science news on Phys.org
Law changed to allow 'unlocking' cellphones
Microsoft sues Samsung alleging contract breach
Best evidence yet for coronal heating theory detected by NASA sounding rocket
HallsofIvy
#2
Nov12-08, 01:32 PM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,363
Quote Quote by ZachN View Post
so -1/x dx= u/(u2+ 1)du - 1/(u2+1 du
The left side give -ln(x), of course. Then anti-derivative of -1/(u2+ 1) is -arctan(u) but to integrate u/(u2+ 1) let v= u2+ 1, dv= 2udu and the integral becomes udu/(u2+ 1)= dv/(2v)= (1/2)ln(v)= (1/2) ln(u2+ 1)= (1/2)ln((y2/x2+ 1)= (1/2)ln((x2+ y[sup]2[sup])/x2= (1/2)ln(x2+ y2)- ln(x).
ZachN
#3
Nov12-08, 02:00 PM
P: 24
Yes, thank you - I was not splitting up the ration into two equations and then integrating. I will try to be more observant from now on.
tiny-tim
#4
Nov13-08, 05:01 PM
Sci Advisor
HW Helper
Thanks
tiny-tim's Avatar
P: 26,151
Hi ZachN!
As an alternative method always look at the answer it may give you a clue as to an easy substitution
in this case, the answer uses tan-1y/x and x2 + y2, so the obvious substitution is into polar coordinates, r and θ.
Try it and see.
ZachN
#5
Nov14-08, 09:56 AM
P: 24
I'll try polar coordinates.
Register to reply
Related Discussions
Homogeneous equation; Initial Value Calculus & Beyond Homework 14
V substitution in homogeneous equations (diff eq) Calculus & Beyond Homework 2
Non-homogeneous differential equation Calculus & Beyond Homework 2
Second order homogeneous Differential EQ with complex coefficients. Calculus & Beyond Homework 2
Homogeneous equation Differential Equations 8
