Purification of sodium chloride
  • Thread starter Thread starter Faizan
    Sodium
The discussion revolves around methods for separating sodium from a mixture of sodium chloride and water-soluble impurities. Participants explore various approaches and clarify the nature of the components involved.
  • Exploratory, Technical explanation, Debate/contested
  • One participant asks how to separate sodium from sodium chloride and water-soluble impurities.
  • Another participant points out that sodium (Na) does not exist in water due to its reactivity, referencing the reaction with water.
  • A third participant clarifies that the original question pertains to sodium chloride (NaCl) and not elemental sodium.
  • There is a humorous remark about the need to specify the types of water impurities for effective separation.
  • One suggestion is made to use an ion exchange resin for the separation process.
  • A participant expresses gratitude for clarification but indicates they still seek an answer to their original question.
  • Another participant suggests that the goal of the separation needs to be clarified, distinguishing between removing Na+ ions and isolating them.
Participants do not reach a consensus on the best method for separation, and multiple competing views and clarifications remain present throughout the discussion.
The discussion lacks specific details about the types of water-soluble impurities and the desired outcome of the separation process, which may affect the proposed methods.
Faizan
How do we separate Sodium from a mixture of sodium chloride and water soluble impurities?
Chemistry news on Phys.org
Sodium? As in Na? In water? HA!
2Na + 2H2O --> 2NaOH + H2
ie. Sodium doesn't exist in water because it will react with it.
No, he mentioned from NaCl, which is a salt and not from the metal Na :)
ha
What other water impurities? You must specify otherwise we will not stroke your rod with much efficiency.
Use an ion exchange resin.
Thanks Monique
Thanks Monique, you clarified my question but still i can't find any answer to my question.
I think you need to clarify your goal a little bit, you want to get rid of the Na+ or you want to isolate Na+.. there is a difference :)
24K
