Register to reply
Find eigen values?
by zeroxff0000ff
Tags: eigen, values
Share this thread:
zeroxff0000ff
#1
Nov13-08, 02:58 AM
P: 2
hello everybody,
Consider '#' as lamda.
How to find roots(eigen values) of characteristic equation |A-#I| = 0.
I know how to find it it using numerical methods.
But can anyone plz show me how to procced for degree 3 equations.
thanks and regards.
Phys.Org News Partner Science news on Phys.org
'Office life' of bacteria may be their weak spot
Lunar explorers will walk at higher speeds than thought
Philips introduces BlueTouch, PulseRelief control for pain relief
HallsofIvy
#2
Nov13-08, 04:59 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,682
Solve the equation! If you cannot factor it and don't want to use a numerical approximation, you could use Cardano's cubic formula:
http://www.math.vanderbilt.edu/~schectex/courses/cubic/
zeroxff0000ff
#3
Nov13-08, 05:33 AM
P: 2
thanks HallsofIvy.
just now i found some methods like factor and remainder theorem from the following link :
http://www.themathpage.com/aprecalc/factor-theorem.htm
can you plz tell me advantage and disadvantage of using factor and reminder theorem.
Office_Shredder
#4
Nov13-08, 06:43 AM
Emeritus
Sci Advisor
PF Gold
P: 4,500
Find eigen values?
I'm not sure what the remainder theorem is, but the factor theorem is usually what's used to solve cubics.... if there's an easy root (like 1, 2, 0, -1) you can reduce the degree of your equation to a quadratic fairly easily, and from there solve for the remaining roots.
You can use the integer root theorem (on the website you posted) to figure out which integers are worth guessing. The advantage is that most problems will have a root that you can find in this way. The disadvantage is that if the polynomial doesn't have an integer root, you can't find any roots using this method. But it doesn't take a lot of time to try, so usually this is the best way to start.
mathwonk
#5
Nov13-08, 08:37 AM
Sci Advisor
HW Helper
mathwonk's Avatar
P: 9,499
the remainder theorem is the theorem from high school algebra that says the remainder of f(x) after dividing it by x-a, is f(a).
HallsofIvy
#6
Nov13-08, 10:20 AM
Math
Emeritus
Sci Advisor
Thanks
PF Gold
P: 39,682
Quote Quote by mathwonk View Post
And in particular, if f(a)= 0, the remainder is 0 so x-a is a factor of f(x).
It seems very strange to me that a person would be working with eigenvalues while not knowing how to solve polynomial equations by factoring!
Register to reply
Related Discussions
Eigen function, eigen value, eigen vector Quantum Physics 2
How to find the eigen vector Calculus & Beyond Homework 10
Eigen values General Math 6
What does it mean to find eigen values and functions of an infinite well? Advanced Physics Homework 1
Eigen values Linear & Abstract Algebra 6
