Can't find normal and tension force
This discussion focuses on calculating normal and tension forces in two physics problems involving centripetal acceleration. In Problem 1, the normal force is determined using Newton's 2nd law, where the net force is the vector sum of the normal force and gravitational force. The correct formula is Fnet = Fnorm - Fgrav. In Problem 2, the tension force must also consider the direction of each force to accurately calculate the resultant force. Specific values attempted by the user, such as 2123.328N and 32.438N, were incorrect, indicating the need for proper application of the principles discussed.
  • Understanding of Newton's 2nd law of motion
  • Knowledge of centripetal acceleration concepts
  • Ability to perform vector addition of forces
  • Familiarity with gravitational force calculations
  • Study the application of Newton's 2nd law in various contexts
  • Learn about centripetal force and its relationship with normal force
  • Explore vector addition techniques for force calculations
  • Investigate examples of tension force calculations in different scenarios
Students and professionals in physics, particularly those studying mechanics, as well as educators looking to clarify concepts related to forces and motion.
badboyben03
i have two problems here where i have to find individual forces.
problem 1: i can't find the normal force. how would i do it?
Code:
<img src=[PLAIN]http://img1.photobucket.com/albums/0903/badboyben03/p01.png>
[/PLAIN]
i tried 2123.328N *(2825.008-701.68) and also tried 701.68N but neither of them worked.
problem 2: i can't find the tension force
Code:
<img src=[PLAIN]http://img1.photobucket.com/albums/0903/badboyben03/p03.png>
[/PLAIN]
i tried 32.438N and 132.948 *(165.386-32.438) but also neither of them worked.
please help me. thanks.
Problem 1.
The normal force must produce the required centripetal acceleration.
This is also the case with problem 3.
Problem 1: Remember that in Newton's 2nd law, Fnet is a vector sum that reduces to (in this problem):
Fnet = Fnorm-Fgrav
Plug in your values appropriately to solve for the normal force on the pilot.
Problem 2: Same exact idea. You need to consider the directions of each force in order to add them together.
  • · Replies 19 ·
