Register to reply
Crystal Scattering
by hayowazzup
Tags: crystal, scattering
Share this thread:
hayowazzup
#1
Nov14-08, 09:21 PM
P: 64
A mono-energetic beam are of neutrons is directed perpendiculary at the surface of a metal crystal whose atom are a constant distance 0.1E-10m apart. The scattered beam of neutrons is found to have maximum intensity at an angle of 25degree to the initial direction. What is the energy (in eV) of the neutrons?
2. Relevant equations
2dsinθ = nλ
E = hc/λ
3. The attempt at a solution
2(0.1E-10)*sin(25) = (1)λ
λ = 8.45E-12 m
E = hc/λ = (6.63E-34)(3E+8)/ 8.45E-12 m = 2.35E-14 J=146890eV
but ans = 45.7eV
Can anyone tell me where goes wrong?
Is that the right equation uses to find the energy of the neutrons?
Phys.Org News Partner Science news on Phys.org
World's largest solar boat on Greek prehistoric mission
Google searches hold key to future market crashes
Mineral magic? Common mineral capable of making and breaking bonds
phz
#2
Nov15-08, 06:35 AM
P: 31
The θ used in your calculation is wrong. Check how it is defined in the 2dsinθ = nλ relation.
E = hc/λ is correct for a photon, but this is a particle with mass and the c has to be replaced with the neutrons velocity. Use the de Broglie-relation λ = h/p and you should be able to get an expression for E. I got the answer E = 43.7eV using my pocket calculator just now which is in the ball park at least.
hayowazzup
#3
Nov15-08, 01:51 PM
P: 64
Φ = 180 - 2θ
θ = (180-Φ)/2 = (180-25)/2 = 77.5
2dsinθ = nλ
λ = 2dsinθ = 2(0.1E-10)sin(77.5) = 1.95E-11m
λ = h/p
λ = h/√(2mE)
E = (h/λ)^2 / 2m
E = (6.63E-34 / 1.95E-11)^2 / 2(1.67E-27) = 3.46E-19 J
E = 3.46E-19 J/ eV = 2.16eV ?
phz
#4
Nov15-08, 02:24 PM
P: 31
Crystal Scattering
The geometry part is still wrong, your choice of θ that is. The rest looks good.
hayowazzup
#5
Nov15-08, 02:35 PM
P: 64
ok I just did a guess
θ = 25 / 2 = 12.5
but why?
phz
#6
Nov15-08, 03:38 PM
P: 31
Your problem text said that the angle between incoming and outgoing ray was 25, but if you've deduced the relation 2dsinθ = nλ you should know that θ is defined as the angle against a perpendicular line against the surface, compare with the law of reflection.
Register to reply
Related Discussions
Light scattering (rayleigh scattering) Introductory Physics Homework 5
Does anyone know about crystal cut? Materials & Chemical Engineering 0
Crystal ID Chemistry 1
