Thread Closed
Magnetic Induction In terms of Creating Charge
Share Thread
Nov18-08, 09:59 AM   #1
Hi,
I'm an industrial designer and I was wondering if there is a way to charge a battery through magnetic induction. I have heard that the way some stop lights work is there are coils below the road, and when the steel body of a car goes over it, it creates a change in charge in those coils. Is there a way a similar idea could be used to charge small batteries?
thanks
PhysOrg.com engineering news on PhysOrg.com
>> Mathematical algorithms cut train delays
>> Researchers design software to detect changes in colour vision
>> Trend study identifies potential for humans and technology to interact in a manufacturing environment
Nov18-08, 04:00 PM   #2
I would think that it is possible however it is not practical.
The traffic lights are using the induction as a sensor, and rely on the moving car, and not as a power source.
If you wanted to charge a battery by the same principal, say in a lab, you would have to physically move something to create that induction, for example youself, or maybe a motor moving a magnetic core through the solenoid, which in turn uses power from another source.
So why not just use the power to charge the battery straight from the main source of power?
Hope that helps
Nov18-08, 04:25 PM   #3
I was hoping to rig up some sort of device that could power the pedestrian/street lights via the traffic that goes over them. Also I was hoping this would be a cheaper solution than using solar power in areas where there might not already be power lines. is this feasible?
Nov18-08, 07:11 PM   #4
If you do some quick calculations with Faradays law you will start to see the problem. A very small voltage would be created across a winding under the road, due to a number of things; The car being realitivlty far from the coil, the coil is underground, cars may not come past so energy would need to be stored. So you would not get enough power out of one coil.
If a lightbulb is ~75W or so, you are not going to create enough energy to run these lightbulbs all night. At a guess you would need probably 20-30 large coils, under a busy road were the cars are going >80km, to start to even get the energy you need. Just a guess though I didn't do the calculations :-)
Who knows, maybe a smart idea will get around this problem...
Thread Closed
Tags
battery, charging, coils, induction, magnetic
Similar discussions for: Magnetic Induction In terms of Creating Charge
Thread Forum Replies
Why the magnetic field is creating around electrons? General Physics 22
ALmost got it, mathematical induction, writing terms seperatley Math & Science Software 2
Formula derivation - Magnetic induction in spinning discs - Magnetic braking Introductory Physics Homework 0
magnetic forces aon currents and magnetic induction Introductory Physics Homework 1
electric charge, creating plasma and keeping it apart General Physics 2
