What is resistance of a DC circuit has resistor n capacitor connect parallel
The discussion centers around understanding the resistance in a DC circuit with a resistor and capacitor connected in parallel. Participants are exploring the implications of this configuration on current flow and time constants, given known values for resistance, capacitance, and voltage.
  • Participants are questioning whether current flows through the capacitor branch and how this affects the overall resistance of the circuit. There is also inquiry into the time constant and its relevance in this parallel configuration.
The discussion is active, with participants providing insights into the behavior of the circuit over time. Some guidance has been offered regarding the behavior of the capacitor and resistor in parallel, though multiple interpretations of the time constant and current flow are being explored.
There are discussions about the rapid charging of the capacitor and its implications for circuit behavior, as well as concerns about the time constant when the resistor is removed from the circuit.
Learner123
the title says everything, any formula that to find resistance in a DC circuit of one resistor and one capacitor connect parallel, as well as the current through each of R and C (the known values are R C and V)
seem to me i = (V/R)e^ (-e/RC), but it only say for series
couldn't find answer in text and on any website
does that mean the current won't go through capacitor branch? and that means if i want to find resistance of the circuit, it's simply R?(nothin to do with C)
and wat about time constant? T = RC? will it be the same like when capacitor n resistor connect series?
It means that after a very short time interval, no current will pass through the capacitor branch, all the current will flow through the resistor.
what about time constant T = RC, will it be zero also?
There is no time-constant in this case since after the initial current spike through the capacitor branch, the circuit simply behaves like a a resistor connected across a potential difference.
thanx a lot, that quite a lot info for me
No problem. If you need to we can treat the network more rigorously, so if you have any more questions please feel free to return.
What happens if we remove the resistor so the circuit consists just of a charged capacitor? Going around the loop we get [itex]q/C = 0[/itex] so q = 0 (i.e., it discharges immediately). Hmm.
That is indeed the case.
Which is why you should be careful while shorting capacitors in the lab :smile:
