| Thread Closed |
Euler Totient. Help needed. |
Share Thread |
| Nov20-08, 04:08 AM | #1 |
Well, the question is to find a formula for [tex]\phi(p^n)[/tex] where [tex]\phi[/tex] is the Euler's totient, and p is a positive prime. 2. Relevant equations [tex]\phi(2^n)[/tex] well in this case here is what i did, i first took n=1, n=2, n=3, and it looks like [tex]\phi(2^n)=2^{n-1}[/tex] but i am failing to prove it, because this is just by observation. Also i tried [tex]\phi(3^n)[/tex] and by observing what happens when, n=1,2,3 etc, this one also looks like the general formula for any n is going to be [tex]\phi(3^n)=2*3^{n-1}[/tex] again i wasn't able to prove this one formally either. I tried in both cases to prove it by induction, but i have a feeling that i need to know more properties about that function in order to know what operations i can perform. We, basically have only learned what euler's function is, and that's it. 3. The attempt at a solution 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution I really don't know whot to go about it. Well, i gave it a shot, but nothing say n=1 then [tex]\phi(p)=p-1[/tex] since the group of invertibles is going to have p-1 elements. Now, let n=2 [tex]\phi(p^2)=??????[/tex] 1. The problem statement, all variables and given/known data 2. Relevant equations 3. The attempt at a solution |
| Nov20-08, 05:10 AM | #2 |
Do you know that 1- xn= (1- x)(1+ x+ x2=+ ... + xn-2+ xn)? That's all you need. The proper divisors or pn are precisely 1, p, ..., pn-1.
| Nov20-08, 09:02 AM | #3 |
Recognitions:
| Nov20-08, 07:50 PM | #4 |
Well, thanks guys a lot, i see it now!
| Thread Closed |
Similar discussions for: Euler Totient. Help needed.
| Totient Function and phi(n)==phi(2n) for odd n | Linear & Abstract Algebra | 13 | ||
| About Euler's totient function | Linear & Abstract Algebra | 2 | ||
| Prove Euler Identity without using Euler Formula | General Math | 36 | ||
| Euler's tricentennial | General Math | 1 | ||
| Results same w/ Euler, Improved Euler, & Runge-Kutta | Differential Equations | 14 | ||
