Why does drop time remain constant regardless of initial horizontal velocity?
The discussion centers on the phenomenon of projectile motion, specifically addressing why the time it takes for an object to fall remains constant regardless of its initial horizontal velocity. Participants explore the relationship between horizontal and vertical motion, considering the effects of gravity and the independence of motion components.
  • Some participants explain that the time to hit the ground is determined solely by the initial height and gravity, independent of horizontal velocity.
  • Others argue that the vertical and horizontal motions are independent, and thus changes in horizontal velocity do not affect the vertical fall time.
  • A participant notes that this reasoning holds true only when ignoring air resistance and other aerodynamic forces.
  • One participant emphasizes the importance of Newton's 2nd law and the vector nature of forces, stating that the acceleration in the vertical direction is governed only by gravity.
Participants generally agree on the independence of horizontal and vertical motion in the context of projectile motion. However, there is some uncertainty regarding the implications of air resistance and how it might affect the discussion.
Limitations include the assumption of negligible air resistance and the focus on ideal conditions without considering real-world factors that could influence the motion.
charlatain
So in projectile motion, an object launched horizontally traveling over a certain displacement (Δx), fall time remains constant regardless of what this horizontal velocity was.
I understand that in this equation:
Δx = v(avg) × Δt
as horizontal velocity increases, displacement also increases, with time serving as the constant of variation. Mathematically, this makes sense. But in reasoning, I'm having a hard time grasping the concept. Just why does time remain constant?​
You should think of the velocity of the object in two components, the vertical and horizontal. Because the time for the object to hit the ground from that height is not going to change since the height hasn't been changed...you only are concerned with the initial height, gravity, and the initial velocity. All in the vertical direction, that is.
Initial vertical velocity, acceleration due to gravity and vertical displacement are not changed by horizontal velocity (at a small scale). There is nothing else to change so why expect time to change. It does seem counter-intuitive but the math reveals the truth.
Yes it does so if you ignore air resistance and any other aerodynamic forces.
Why? Well it should be pretty obvious that if you exclude any aerodynamic forces then the horizontal component of velocity can have no effect at all on the vertical forces (and visa versa). Does that make sense?
I suppose.
So what I understand (of course, air resistance being negligible):
The horizontal (x) motion of an object is entirely independent on its vertical (y) motion. Initial vertical velocity, acceleration due to gravity and vertical displacement are not affected by horizontal velocity, therefore time is not expected to change either. For example, simply dropping an object down vertically or launching it horizontally at any velocity will yield the same drop time simply because horizontal and vertical components CANNOT influence one another, given that the height, initial vertical velocity, acceleration due to gravity are kept constant.
Is that somewhere near?
You are on the right track here. Allow me to be very clear, and systematic.
Essentially we are talking about Newton's 2nd law, F=ma. The key concept is that this equation is a vector equation. It decomposes into three different equations, relating the forces in the x-direction to the acceleration in the x-direction, and similarly for the y and z directions. Let's call these the x-force, y-force, and z-force equations.
Consider the y-force equation. The gravity force, as we know, always points downwards; hence the gravity force shows up in the y-force equation. But the gravity force is the only force pointing in the y-direction; so the the acceleration in the y-direction is only governed by the gravity force. Hence the "drop time" as you call it has no dependency on the velocity in the x-direction.
I believe this is the most systematic reasoning by which you would come to your conclusion. Please reply if you still don't understand.
  • · Replies 25 ·
  • · Replies 37 ·
