Thread Closed
radius of curvature of the cornea
Share Thread
Nov20-08, 09:25 PM   #1
The cornea, a boundary between the air and the aqueous humor, has a 3.0cm focal length when acting alone.
What is its radius of curvature?
2. Relevant equations
n(1)/s + n(2)/s' = (n(2)-n(1))/R
where, n is the index of refraction (unitless), s' is the img dist (cm). and s is the obj. dist (cm). R is the radius (cm).
also, 1/s + 1/s' = 1/f
where, f is the focal length.
also, n(1) is air having a index of refraction of 1.00
and n(2) is the aqueous humor having a index of refraction of 1.34
3. The attempt at a solution
So, I assumed since only f was given as 3.0cm that 1/s' + 1/s could be 1/6.0cm + 1/6.0cm = 1/3.0cm. Then that would give 1.00/6.0cm + 1.34/6.0cm = (1.34-1.00)/R giving R to be 0.87cm but it says that is wrong. Any ideas??? Also, I thought there was a equation editor for this website? I can't seem to see it... Is it only for the premium members?
PhysOrg.com science news on PhysOrg.com
>> New language discovery reveals linguistic insights
>> US official: Solar plane to help ground energy use (Update)
>> Four microphones, computer algorithm enough to produce 3-D model of simple, convex room
Nov20-08, 09:45 PM   #2
Radius of curvature is the distance from the cornea to the centre of curvature. If the focal length is half this distance, what do you think the answer is?
Nov20-08, 10:30 PM   #3
Are you implying that it is 2*f=R? 6.0cm is not the right answer if so. That only applies for mirrors right? They seem to be indicating the "air" and the "aqueous humor" in the problem... both of which have given index of refractions in the book. I believe the equation used to solve this problem will deal with the index of refraction... It is hinted in the problem statement pretty much. Thanks for the help though... let me know if you have any other thoughts.
Nov21-08, 11:37 AM   #4
Recognitions:
Homework Helper Homework Help
As for your Equation editing there is a Σ at the top of the message window that is an aid to inserting LaTex into messages. If you want to see how some equations are constructed just click on them and the underlying LaTex is revealed.
You can also take advantage of the X2 and X2 buttons for subscripting and superscripting.
n(1)/s + n(2)/s' = (n(2)-n(1))/R yields:
[tex] \frac{n_1}{s_1} + \frac{n_2}{s_2} = \frac{n_2 - n_1}{R} [/tex]
As to your problem ...
Wouldn't the lens makers relationship be the way to approach it?
[tex] \frac{1}{f} = (n-1)*(\frac{1}{R} + \frac{1}{R}) [/tex]
Nov22-08, 01:20 PM   #5
I guess you could approach it from the lens makers... I don't see how though. I'm given only one radius... in your formula that needs to be a R subnot 1 and 2. Also, I'm dealing with two index of refraction values. With the amount of known values I have I cannot seem to piece them together into a formula that satisfies utalizing them all. Am I missing something? Am I supposed to use only one index of refraction and pull another radius out of the sky? hmm, thanks for the help anyways... always appreciated. i'm just frustrated... it is due tomorrow morn.
Nov22-08, 02:03 PM   #6
It is useful to think about the definition of focal length. How is focal length defined?
Nov22-08, 03:01 PM   #7
Recognitions:
Quote by spaghed87 View Post
What is the n of the cornea? Or is it perhaps the same as the lens? In which case there is no second radius and the only consideration is the outer radius so the f*(n-1) = R?
Nov22-08, 03:06 PM   #8
Quote by LowlyPion View Post
That formula will only apply if you are focusing into a medium with index 1. Therefore it applies well to lenses, but can get confusing with single interfaces. It is simpler to use the original equation and use the definition of focal length.
Nov22-08, 07:38 PM   #9
I did f*(n-1) = R even before you mentioned the equation in that form. Maybe the masteringphysics website is off. I derived that formula by taking s=f and s' being equal to inifinity for an answer of 1.02cm (we are on the same boat). Yes, it is focusing into a medium with an index of 1. This beats me. I'm down to two attempts left. I'll still pass this class just fine... I just hate not getting an answer.
Nov22-08, 08:22 PM   #10
Well, you're almost correct. What do s and s' refer to? Where is the light coming from, and where is it focusing (remember, we're talking about the eye, not an abstract mathematical equation )?
Thread Closed
Tags
cornea, curvature, focal length, lens, radius
Similar Threads for: radius of curvature of the cornea
Thread Forum Replies
Radius of curvature Cosmology 3
Is the schwarzchild radius a radius of curvature? Special & General Relativity 9
radius of curvature Introductory Physics Homework 1
radius of curvature Calculus 10
radius of curvature Introductory Physics Homework 0
