Can a Copper Cable Effectively Pick Up Terahertz Signals?
The discussion revolves around the feasibility of using a copper cable to effectively pick up terahertz signals, particularly in the context of electromagnetic radiation across a wide frequency spectrum. Participants explore concepts related to waveguides, skin effect, and the limitations of copper in high-frequency applications.
  • One participant questions whether a copper cable can pick up all frequencies from DC to visible light, expressing particular interest in terahertz frequencies and noting a lack of experience in electromagnetics.
  • Another participant mentions that while a single wire can carry radio frequencies, it would incur significant radiation loss, suggesting that coaxial cables or waveguides are typically used for RF transmission.
  • A different participant argues that dielectric waveguides are often more efficient than copper waveguides for frequencies between 300-1000 GHz, but acknowledges the possibility of using differential copper lines in the THz regime.
  • There is a discussion about the role of waveguides as receivers or antennas, with clarification that waveguides themselves are conduits and require additional components, like horns or parabolic reflectors, to function as antennas.
Participants express a range of views on the effectiveness of copper cables and waveguides for terahertz signals, with no consensus reached on the best approach or the feasibility of using copper for this purpose.
Participants note various limitations, such as the cut-off frequency for waveguides, the skin effect in copper, and the challenges associated with manufacturing waveguides suitable for higher frequencies.
konrad109
Hi, recent EE graduate, I'm working on a project for myself. I dealt with mostly controls, signals, and digital stuff, and not enough electromagnetics or RF so I am pretty clueless here.
If I were to radiate the full electromagnetic spectrum from dc to visible light onto a copper cable, would it pick up all the frequencies or would it kill off the higher frequencies entirely? Mainly I am interested in a few Terahertz (infrared).
I know I'm missing a lot of info here so sorry if sound ignorant but this wasn't my area of study and its hard to pick this stuff up on your own. I know there are such things as waveguides and something with the ground plane when you are at really high frequencies but all I have to work on is what I learned in my electromagnetic interference class.
With skin effect, I calculated that at that frequency a 20 mil copper cable would have
R per meter = 447 ohms
L per meter = 2.4 pH
They both get smaller as the thickness of the cable decreases
I made a lumped circuit approximation (not sure if this is correct to do with a 1meter cable and 3 THz signal) where I put 1 of each in series on each side of a load resistor and do AC analysis in LTSpice, which gives me an LP filter with w_0 of roughly 10 THz. So it seems like a 1m cable like this cable would be able to pass a signal at the frequencies I am interested in, but this doesn't really seem feasible because its saying that a really thick copper cable could pass visible light. I know nothing about antennas so I don't know if it could pick up the signal either. Is it at all possible to pick up a THz signal with a copper wire with proper filtering and gain or am I wasting my time?
There are modes where a single wire can carry radio frequency but not without a lot of radiation and therefore loss.
RF is normally carried by coaxial cable or waveguide. Coax has a 'cut-off' because when the inner diameter of the outer conductor is greater than half a wavelenth it also behaves like a waveguide and if the frequency is even higher waveguide higher modes start to appear.
Waveguide tend to be used over a limited range of frequencies. ( less than an ocatave). There is a minimum cut-off where the half wavelength is less than the largest dimension of the waveguide cross section (e.g longest side in a rectangular guide). The usually mode is TE10. Using a waveguide at a higher frequencies outside its normal band while result in multiple higher order modes appearing.
You needs to read up on waveguide and modes.. TE10 .. TE11. TM10. Transverse Electric. Transverse Magnetic.
I think in theory light would propagate through plain copper tube if it was slightly bigger than half a wavelength. It might be rather difficult to manufacture.
For frequencies in the range 300-1000 GHz it is usually more efficient to use a dilelectric waveguide (basically a plastic pipe) than a copper waveguide.
However, it is actually possible to use differential copper lines for frequencies in the THz regime (there was a talk about numerical simulations of this at a Comsol conference, I have the paper on a CD somewhere).
Waveguides also act as receivers/antennas for higher frequencies?
I am very interested in that paper.
The waveguide itself is just a conduit to guide the EM waves; it is not an antenna itself. The waveguide will end in a horn of some sort, which acts as the TX/RX "antenna". It will often be placed at the focus of a parabolic reflector, for example, to increase the gain of the antenna dramatically...
  • · Replies 26 ·
