Lower and upper cutoff frequencies
  • Thread starter Thread starter aruna1
    Frequencies
The discussion focuses on determining the upper and lower cutoff frequencies of an amplifier using input signal frequencies and corresponding voltage gains (Av). The cutoff frequency is defined as the -3 dB point, which corresponds to the square root of 1/2 of the passband voltage. To find these frequencies, one must identify the highest gain point, consider it as the zero gain reference, and then interpolate between values to locate the -3 dB points. This method is essential for analyzing amplifier performance in frequency response.
  • Understanding of amplifier voltage gain (Av)
  • Knowledge of frequency response analysis
  • Familiarity with dB (decibel) calculations
  • Basic graphing skills for interpolation
  • Learn how to graph voltage gain versus frequency for amplifiers
  • Study the concept of -3 dB points in frequency response
  • Explore interpolation techniques for data analysis
  • Investigate tools for simulating amplifier frequency response, such as LTspice
Electronics students, audio engineers, and anyone involved in amplifier design and analysis will benefit from this discussion on cutoff frequencies.
aruna1
i have values of input signal frequencies and relevant voltage gains(Av) of a amplifire.and i want to find upper and lower cutoff frequencies by drawing a graph.can someone tell me how to find upper and lower cutoff frequencies with following values.
thanks
here is values
http://img227.imageshack.us/my.php?image=valueskc2.jpg
the cutoff frequency is the -3 db point (squareroot of 1/2 of the passband voltage). Take the highest point and assume that is the zero gain point and go down -3 db. You'll have to Interpolate between some values.
can you please explain this with given values? i mean with gains given.thanks
30K
10K
