Storing Ammonia Phase Diagram Answers
  • Thread starter Thread starter doggieslover
    Ammonia
The discussion revolves around understanding the phase diagram of ammonia, specifically focusing on identifying lines that represent various phase transitions such as boiling, sublimation, and melting. Participants are analyzing specific points on the diagram to determine the correct endpoints for these processes.
  • Participants are attempting to identify the correct lines on the phase diagram for boiling, sublimation, and melting processes. There are questions about the interpretation of the diagram and the specific conditions that define each phase transition.
Some participants are questioning the accuracy of their interpretations of the phase diagram, particularly regarding the endpoints for boiling and sublimation. There is an ongoing exploration of the definitions of the phases and the conditions under which ammonia exists in different states. Guidance has been offered regarding the interpretation of the lines and the phases they represent.
Participants are working under the constraints of a homework assignment, which may impose specific requirements for the answers, such as the need for correct ordering of points and adherence to the definitions of phase transitions. There is also a mention of the need for precision in reporting the coordinates of the triple point and the maximum pressure for liquid ammonia storage.
doggieslover
http://session.masteringphysics.com/problemAsset/1003323/16/152457.jpg
Part A
The line between which two points would describe a process of liquid ammonia boiling completely away?
Express the answer as two letters representing the endpoints of the line in order so that going from the first letter to the second letter would show a process of boiling. Be careful to put the letters in the correct order.
Okay, I got tried EG and FG already and they are both incorrect.
Part D
The line between which two points would describe a process of sublimation for ammonia?
Express your answer with two letters ordered in the direction of sublimation. Be careful to put the letters in the correct order.
I know the sublimation curve is at BC, but I don't think that's the answer they are looking for?
Part F
The line between which two points would describe the process of complete melting of ammonia?
Express your answer as two letters ordered in the direction of melting. Be careful to put the letters in the correct order.
Again, melting curve is at CD but I don't think that's what they are asking.
Part G
One of the most important points on a phase diagram is the triple point, where gas, liquid, and solid phases all can exist at once. What are the coordinates ( T_triple, p_triple) of the triple point of ammonia in the diagram?
Express your answer as an ordered pair. Determine the temperature to the nearest 5K and the pressure to one significant digit.
Part H
At one atmosphere of pressure and temperatures above -33.3 Celsisus, ammonia exists as a gas. For transportation, ammonia is stored as a liquid under its own vapor pressure. This means that the liquid and gas phases exist simultaneously. If a container of ammonia is transported in an temperature-controlled truck that is maintained at no greater than 330K, what maximum pressure p must the sides of the container be able to withstand?
Express the answer numerically in atmospheres to one significant figure.
I don't think you're reading your phase diagram correctly. Any point that borders two phases represents a condition that allows NH4 to exist in both of those phases simultaneously. That the question specifically reads "liquid ammonia boiling completely away" means to me that they're looking for a line that would connect a point where NH4 exists entirely as a liquid to one where it is entirely a gas, without passing through the solid phase. I would also make similar assumptions about the melting and sublimation lines.
But doesn't the line from E to G indicate where NH_4 "exists entirely as a liquid to one where it is entirely a gas, without passing through the solid phase"?
And it's incorrect, I mean that is the only line possible right?
Point G is entirely in the gaseous phase, but point E is straddling the interface between the liquid and gas phases, so it's not entirely a liquid. Point H, however...
BTW - before somebody gives me grief for a bad chemical formula, NH4+ is technically the ammonium ion, where NH3 is the correct formula for ammonia. That's what I get for posting past midnight. :)
