Help with Laplace Transformations and 2nd order ODEs
The discussion revolves around solving second-order ordinary differential equations (ODEs) using Laplace transformations. The original poster presents several ODEs and expresses difficulty in applying Laplace transforms to find solutions.
  • Participants explore the application of Laplace transforms to the given ODEs, discussing the transformation of derivatives and the use of initial conditions. Questions arise regarding the notation and the steps involved in deriving expressions for the Laplace transforms of the functions.
The discussion is ongoing, with participants providing insights into the transformation process and clarifying the use of specific formulas. Some participants express confusion over the notation and the steps taken, while others attempt to clarify these points. There is no explicit consensus yet on the final approach to solving the ODEs.
Participants are working under the constraints of homework rules, which may limit the amount of direct assistance provided. The original poster has indicated a lack of understanding of the Laplace transformation process, prompting further exploration and questioning of assumptions and definitions related to the topic.
TFM
Solve the following problems using Laplace Transforms:
[tex]y' - y = 2e^t, y_0 = 3[/tex]
[tex]y'' + 4y' + 4y = e^{-2t}, y_0 = 0, y_0' = 4[/tex]
[tex]y'' + y = sin(t), y_0 = 1, y_0' = 0[/tex]
[tex]y'' + y = sin(t), y_0 = 1, y_0' = -\frac{1}{2}[/tex]
N/A
I don't seem to understand how to use Laplace Transformation to solve ODE's! If anyone can help, I will be most grateful.
TFM
lets look at the first one: let L(F(t)) denote the laplace of F(t)
in general, you say that:
L(y'(t))-L(y(t))=L(2e^t) call this (1)
L(y(t))=y (in terms of s)
L(y'(t))=sL(y(t) - y(0) (This is one of the formulas from the table of laplace transforms)
=sy-3
so, substituting these back into (1): sy-3-y=2/(s-1) (also from the tables)
make y the subject, then you should get an expression for y in terms of s.
Then to find y(t) (which is what you are looking for), you must find the inverse of y.
I hope all is clear.
=sy-3
Where did the 'in terms of S' come from?
TFM
It might be confusing to use the same label y for the function und its Laplace transform. Better come up with a new letter like Y:smile:
You then have to solve (according to Sara)
[tex]sY(s)-3-Y(s)=\frac{2}{s-1}[/tex]
for Y(s) and find the inverse Laplace transform of this function.
Okay let's see if this makes sense:
you have the orginal equation, F(t)
[tex]y' - y = 2e^t[/tex]
then you make L(f(t)):
[tex]L(y'(t)) - L(y(t)) = L(2e^t)[/tex] ---(1)
I still can't see how you have gone from here to here:
TFM
that is not from one step to another.
L(y'(t))-L(y(t))=L(2e^t) this is something
and
L(y(t))=Y is something else.
In other words, LET L(y(t))=Y
so therefore, L(y'(t))=sY-3
Let's see then...:
[tex]L(F(t): L(y'(t)) - L(y(t)) = L(2e^t)[/tex] ---(1)
and also:
[tex]L(y(t)) = Y[/tex]
so inserting into (1)
[tex]L(F(t): L(y'(t)) - Y = L(2e^t)[/tex]
[tex]L(y'(t)) = Y + L(2e^t)[/tex]
I see now where the 3 comes from, [tex]y_0 = 3[/tex]
[tex]L(y'(t)) = Y - y_0[/tex]
[tex]L(y'(t)) = Y - 3[/tex]
substitute back into (1):
[tex]Y - 3 - L(y(t)) = L(2e^t)[/tex]
does this look right so far?
TFM
you made a small mistake,
L(y'(t))=sY-3
because you must use the formula:
L(F'(t))=sL(F(t))-F(0)
Im not sure but I think you are expected to know this general formula.
so this gives:
sY-3-L(y(t))=L(2e^t)
Yes, the formula:
[tex]L(F(t)) = sL(F(t)) - F(0)[/tex]
looks useful. I assume the [tex]sL(F(t))[/tex] is inequivalent to: [tex]s*L(y(t)) = Y[/tex]
so:
[tex]L(y'(t)) = sY - 3[/tex]
putting back into (1)
[tex]sY - 3 - sY - 3 = L(2e^t)[/tex]
does this look right?
TFM
The star means convolution (in Laplace language) so it is inequivalent
You have:
L(y'(t))-L(y(t))=L(2e^t) this is (1)
we said let L(y(t))=Y
and then we know that L(y'(t))=sY-3
so putting into (1) gives:
sY-3-Y=L(2e^t)
Why are you putting sY-3 twice?
You have:
sY-3-Y=L(2e^t)
I meant the star as in times, Sorry.
I am not sure, how am I putting in sY-3 twice? sY-3-Y=L(2e^t) only has sY - 3 in once?
TFM
exactly so again you have to remember:
(A) we said let L(y(t))=Y
(B) and then we know that L(y'(t))=sY-3
(C) sY-3-Y=L(2e^t)
These are the three main steps that should give you the equation of Y in terms of s.
So, what would you do next?
Well, judging from your first post, rearrange into Y?
so this would be:
[tex]sY-3-Y=L(2e^t)[/tex]
put 3 to one side:
[tex]sY-Y=L(2e^t) + 3[/tex]
factorise out Y:
[tex]Y(s - 1) = L(2e^t) + 3[/tex]
divide by (s - 1):
[tex]Y = \frac{L(2e^t) + 3}{s - 1}[/tex]
Does this look right?
TFM
no, before you 'put to one side' on your second step, you have to find the laplace of
2e^t
sY-3-Y=L(2e^t)
so,
sY-3-Y=2/(s-1)
(do you know that L(2e^t)=2/(s-1) ?)
now, you make Y the subject.
I have a table with Laplace conversions, and it gives:
[tex]e^{-\alpha t} = \frac{1}{p + \alpha}[/tex]
so
[tex]2e^{t} = \frac{2}{p + t}[/tex]
I'm assuming p and s are equivilant
so now:
[tex]sY-3-Y = L(2e^t)[/tex]
[tex]sY-3-Y = \frac{2}{s + t}[/tex]
now take over the 3:
[tex]sY-Y = \frac{2}{s + t} + 3[/tex]
factorise Y:
[tex]Y(s - 1) = \frac{2}{s + t} + 3[/tex]
thus giving Y
[tex]Y = \frac{\frac{2}{s + t} + 3}{s - 1}[/tex]
Does this look better?
TFM
e^(-at)=1/(s-a)
so: (the right hand side is the laplace so it has nothing to do with t)
2e^(t)=1/(s+1) (since in our case, -a=1)
Now, make Y the subject from:
sY-3-Y=1/(s+1) (do you agree?)
I feel slightly sill, I meant to do that, but didn't :redface:
So:
[tex]sY-3-Y = \frac{2}{s + 1}[/tex]
now:
[tex]sY-Y = \frac{2}{s + 1} + 3[/tex]
[tex]Y(s - 1) = \frac{2}{s + 1} + 3[/tex]
[tex]Y = \frac{\frac{2}{s + 1} + 3}{s - 1}[/tex]
Is this right?
TFM
Im sorry, i misread; the L(2e^t) means that our a=1 so that means L(2e^t)=2/(s-1)
not 2/(s+1)
but your steps are correct and so your Y would be:
sY-3-Y=2/(s-1)
Y(s-1)=2/(s-1) +3
so Y=2/(s-1)^2 + 3/(s-1) (by dividing both sides by s-1)
is this clear?
so, what would you do next?
so:
[tex]Y = \frac{\frac{2}{s - 1} + 3}{s - 1}[/tex]
is the same as:
[tex]Y = \frac{2}{(s - 1)^2}+\frac{3}{s - 1}[/tex]
so now, from your first post again, I need to find the inverse:
thus:
[tex]\frac{1}{Y} = \frac{(s - 1)^2}{2}+\frac{s - 1}{3}[/tex]
TFM
no, carefull... when i say inverse i don't mean 1/Y;
Y=2/(s-1)^2 + 3/(s-1) call this (2) (This is you Laplace of the function you are looking for)
So you want to find the function in terms of t that would give you (2) when you find its laplace. so you want to find a function of t.
so, Y(t)= something that when you find its laplace you would get (2)
so, first, what is the function in terms of t that when you find its laplace you would get 2/(s-1)^2 ? (you would need to use your tables)
The closest I can find is:
[tex]\frac{e^{-at}-e^{-bt}}{b - a} = \frac{1}{(p + a)(p + b)}[/tex]
or
[tex]\frac{ae^{-at}-be^{-bt}}{b - a} = \frac{p}{(p + a)(p + b)}[/tex]
TFM
ok, let's first look at: 3/(s-1) since it's simpler:
L(e^t)= 1/(s-1) as we saw before
so to get 3/(s-1) this means the function is 3e^t
yes?
Yes, that makes sense and agrees with the similar one in the table.
TFM
ok, so now what is the inverse of 2/(s-1)^2 ?
You have to use the first shift theorem which should be on the tables.
Would it not be:
[tex]2 \frac{1}{(p + a)(p + b)}[/tex]
with a and b both minus 1 giving:
[tex]\frac{2}{(p - 1)(p - 1)}[/tex]
TFM
when you find the function, it should be in terms of t. eg:
inverse laplace of 3/(p-1) is 3e^t (from tables) (in terms of t's no p's; the p's are only in the laplace not the inerse of the laplace.
inverse laplace of 2/(p-1)^2 is...? find from tables, do you know the first shift theorem?
Its not on the table, and I can't seem to find it in my notes...
TFM
Ok, the first shift theorem says that:
if you have a function that looks like: e^(at)F(t);
the laplace of that is the laplace of F(t) but instead of putting p, you put p-a
eg: L(e^3t(t))
we know that laplace of t is 1/p^2 (you know that from the tables right?)
and so here a=3 so the laplace of e^(3t)(t)=1/(p-3)^2
so, where ever you have p, you replace with p-a in this case, p-3
Do you agree??
so could you now find the inverse of 2/(s-1)^2
do have any ideas?
Thus bit is right?:
[tex]\frac{3}{(p-1)} : 3e^t[/tex]
okay. so now I have to use first shift theorem on:
[tex]2/(p-1)^2[/tex]
Would this not give:
[tex]2/((p - 3)-1)^2[/tex]
I think that bit is wrong though?
Also, my table doesn't have t on its own, but I will accept that t goes to 1/p^2
TFM
your table has t^n so just say that n is one to give laplace is 1/p^2
so, for 2/(p-1)^2
why did you do this: 2/((p-3)-1)^2 ?
You have to find a function in t such that when you find the laplace of it, you would get 2/(p-1)^2. So, don't apply the first shift theorem on it, you have to unapply the first shift theorem...does that make sense?
Hint: what is the laplace of 2t ? (using tables with n=1)
