Thread Closed
Help with Laplace Transformations and 2nd order ODEs
Share Thread Thread Tools
Nov26-08, 12:01 PM   #52
TFM
so split it up:
[tex] \frac{1}{(s + 2)^3} + \frac{4}{(s + 2)^2} [/tex]
[tex] \frac{4}{(s + 2)^2} = 4te^{-2t} [/tex]
okay so for:
[tex] \frac{1}{(s + 2)^3} [/tex]
we need to use:
[tex] t^n = \frac{n!}{s^{n + 1}} [/tex]
so, would this mean:
[tex] \frac{3!}{s^3} = t^2 [/tex]
we have
[tex] \frac{1}{s^3} [/tex]
Is this relevant, or am I going the wrong way for this one/
TFM
Nov26-08, 12:43 PM   #53
for 1/(s+2)^3:
laplace of t^2 is 2!/(s^3) so it is 2/s^3
i dont know why you put 1/s^3.
but you have the right idea.
so if the laplace of t^2 is 2!/(s^3), what is the inverse of 1/(s+2)^3 ?
Nov26-08, 12:52 PM   #54
TFM
So:
[tex] t^2 = \frac{2!}{s^3} [/tex]
we have [tex] \frac{1}{(s + 2)^2} [/tex]
so using the Shift, would that be something like:
[tex] \frac{1}{(s + 2)^2} = (t - 2)^2 [/tex]
bvut I think even it is slightly wrong at least because it doesn't deal with the fact that the top value isn't 2!
TFM
Nov26-08, 01:00 PM   #55
For 1/(s+1)^3, let's just look at 1/s^3 ; we know that t^2 is 2/s^3 so 1/s^3 will be the inverse of (1/2)(t^2) right?
but, we dont want 1/s^3, we want 1/(s+1)^3, so what do we do (like we did before)?
Nov26-08, 01:13 PM   #56
TFM
First Shft Theorem
Ok, the first shift theorem says that:
if you have a function that looks like: e^(at)F(t);
the laplace of that is the laplace of F(t) but instead of putting p, you put p-a
eg: L(e^3t(t))
we know that laplace of t is 1/p^2 (you know that from the tables right?)
and so here a=3 so the laplace of e^(3t)(t)=1/(p-3)^2
so, where ever you have p, you replace with p-a in this case, p-3
Do you agree??
[tex] t^2 = 2/s^3 [/tex]
[tex] \frac{1}{2}t^2 = \frac{1}{s^3} [/tex]
using FST
[tex] \frac{1}{2}t^2 = \frac{1}{b^3} [/tex], where b = s + 1
would this make it:
\frac{1}{2}(t+1)^2 = \frac{1}{b^3} [/tex]
TFM
Nov26-08, 03:54 PM   #57
I dont see any e's in your answer (there should be).
now as we did before, the second fraction is the laplace transform of: 4te^(-2t)
because if you find the laplace of 4t, this will give you 4/s^2 but we dont want s at the bottom, we want (s+2) so thats why we use the first shift theorem and times the 4t by e^(-2t).
now, can you do the same for the 1/(s+1)^3
Nov27-08, 08:37 AM   #58
TFM
Okay so:
4t will give you 4/s^2,but we don't want s at the bottom, we want (s+2) so thats why we use the first shift theorem and times the 4t by e^(-2t).
so would this mean:
[tex] t^2 would give: \frac{2}{s^3} [/tex]
thus would:
[tex] \frac{2}{(s + 1)^3} be \frac{1}{2}t^2 e^{-t} [/tex]
TFM
Nov27-08, 02:42 PM   #59
very good!!
Nov27-08, 02:51 PM   #60
TFM
Great
So now:
[tex] Y = \frac{1}{(s + 2)^3} + \frac{4}{(s + 2)^2} [/tex]
this goes to:
[tex] Y = \frac{1}{2}t^2 e^{-t} + 4te^{-2t} [/tex]
So now we put this value of Y back into:
[tex] s^2(Y) - 4 + 4(sY) + 4Y = \frac{1}{s + 2} [/tex]
TFM
Nov27-08, 03:02 PM   #61
y(t)=(1/2)t^2(e^-t) + 4t(e^-2t)
This is the answer. dont substitute anything into anything.
Nov27-08, 03:06 PM   #62
TFM
Excellent.
So
[tex] y(t) = \frac{1}{2}t^2 e^{-t} + 4te^{-2t} [/tex]
Tomorrow, I'll start (c), if thats okay?
TFM
Nov28-08, 03:45 PM   #63
yep thats fine
Nov29-08, 12:12 PM   #64
TFM
Okay, so:
(c):
[tex] y'' + y = sin(t), y_0 = 1, y_0' = 0 [/tex]
L(y(t)) = Y
L(y'(t)) = sL(y(t)) - y(0)
L(y''(t)) = sL(y'(t))-y'(0) = s^2(L(y(t))-sy(0)-y'(0)
there is no y',
[tex] L(y(t)) = Y [/tex]
[tex] L(y'(t)) = sL(y(t)) - 1 [/tex]
[tex] L(y''(t)) = sL(y'(t))-0 = s^2(L(y(t))-sy(0)-y'(0) [/tex]
and for the sin(t)
[tex] sin(\alpha t) = \frac{\alpha}{p^2 + \alpha^2} [/tex]
since alpha = 1:
[tex] sin(t) = \frac{1}{p^2 + 1} [/tex]
Is this okay, I am not quite sure because the lack of y'
TFM
Nov29-08, 12:19 PM   #65
That is absolutely right.
what next?
Nov29-08, 12:30 PM   #66
TFM
Okay so:
[tex] L(y''(t)) = s^2(L(y(t))-sy(0) [/tex]
So now I substitute these into the original equation:
[tex] y'' + y = sin(t) [/tex]
[tex] s^2(L(y(t))-sy(0) + Y = \frac{1}{p^2 + 1} [/tex]
Is this okay? Do I substitute y(0) into sy(0), or is there another value/leave it alone?
TFM
Nov29-08, 12:49 PM   #67
That's fine
substitute y(0) and also substitue the value L(y(t))
Nov29-08, 12:59 PM   #68
TFM
Okay, so
[tex] s^2(Y)-1 + Y = \frac{1}{p^2 + 1} [/tex]
[tex] Ys^2 + Y - 1 = \frac{1}{p^2 + 1} [/tex]
Now I need to make the Y the subject:
[tex] Ys^2 + Y = \frac{1}{p^2 + 1} + 1 [/tex]
factorise out
[tex] Y(s^2 + 1) = \frac{1}{p^2 + 1} + 1 [/tex]
divide through:
[tex] Y = \frac{\frac{1}{p^2 + 1} + 1}{s^2 + 1} [/tex]
Now I need to find the inverse.
Firstly, split it up into two fractions:
[tex] Y = \frac{\frac{1}{p^2 + 1}}{s^2 + 1} + \frac{1}{s^2 + 1} [/tex]
Does this look okay?
TFM
Thread Closed
Thread Tools
Similar Threads for: Help with Laplace Transformations and 2nd order ODEs
Thread Forum Replies
Laplace transformations Calculus & Beyond Homework 3
Numerical method to solve high order ODEs. Differential Equations 4
From 2 1st order ODEs to 1 2nd order ODE? Differential Equations 6
Separating a higher-order ODE into 1st-order ODEs Calculus & Beyond Homework 0
Help solving non homogenous second order ODEs Calculus & Beyond Homework 2
