High pressure gases specific heat
This discussion focuses on calculating the reaction heat in an ammonia converter, specifically requiring the specific heats of nitrogen (N2), ammonia (NH3), argon (Ar), and methane (CH4) at 500°C and 200 bar. The NIST website was referenced for specific heat values, although it does not provide data for ammonia at the specified pressure. The specific heat values obtained are: Nitrogen (Cv: 0.1977, Cp: 0.2738), Ammonia (Cv: 0.6080, Cp: 0.7906), Argon (Cv: 0.07550, Cp: 0.1314), and Methane (Cv: 0.8018, Cp: 0.9490).
  • Understanding of thermodynamic properties of gases
  • Familiarity with specific heat calculations
  • Knowledge of high-pressure gas behavior
  • Experience using the NIST Chemistry WebBook
  • Research high-pressure gas thermodynamics
  • Explore advanced specific heat calculation methods
  • Investigate alternative databases for gas properties at high pressures
  • Learn about ammonia converter design and operation
Chemical engineers, thermodynamic researchers, and professionals involved in ammonia synthesis and high-pressure gas applications will benefit from this discussion.
stefaan
I want to calculate the reaction heat in a ammonia convertor but I need some
specific heats of N2,NH3,Ar and CH4 at 500°C and 200bar. I could find data at 500°C but not at that pressure.
thanks Stefaan
Hi Stefaan,
I was going to suggest the NIST website but I see they don't go up that high in pressure for ammonia at least.
http://webbook.nist.gov/chemistry/fluid/
Values below are in Btu/lbm-F.
Fluid / Cv / Cp
Nitrogen / .1977 / .2738
Ammonia / .6080 / .7906
Argon / .07550 / .1314
CH4 / .8018 / .9490
  • · Replies 23 ·
