Thread Closed
voltage and current calculation on a mixed circuit
Share Thread Thread Tools
Nov23-08, 01:48 PM   #1
I have the following circuit
R1 = 22 ohm, R2 = 39, R3 = 82, R4 = 100,R5 = 10
and V = 2volt
I'm asked to calculate the voltage and current over de resistors
when the switch is open and when the switch is closed
2. Relevant equations
when 2 resistors form a combination the current is the same and V = IR
when 2 resistors are in parallell there voltages are the same and Ii = V/Ri
3. The attempt at a solution
well when the switch is open I obtain the following
the resistors R1 and R4 form a combination and so do R2 and R3 the voltage remains equal for both combinations so we can easily calculate the current
I1=I4 = 2v/(22+100)ohm = 0.016 A
now we find the voltage over both resistors
V1= 0.016 * 22 = 0.361 Volt
v4 = 0.016 * 100
Same way for I2 and I3
But I'm stuck when the switch is closed how do I calculate the current and voltage then ?
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Nov23-08, 05:13 PM   #2
ptr
It might be well to read up on "Delta-Wye" transformations.
Nov23-08, 05:26 PM   #3
Mentor
Quote by sylvarant View Post
[b] But I'm stuck when the switch is closed how do I calculate the current and voltage then ?
Have you learned how to write KCL equations yet? Write the two KCL equations for the left and right nodes, and solve for the two unknowns V(left node) and V(right node).
Thread Closed
Thread Tools
Similar Threads for: voltage and current calculation on a mixed circuit
Thread Forum Replies
CIRCUIT ANALYSIS: 3 Resistors, 3 Voltage Src, 1 Current Src - Find v1, v2, v3 Engineering, Comp Sci, & Technology Homework 3
CIRCUIT ANALYSIS: 4 resistor, Current src, Voltage src, V.C.V.S. - Find node Voltages Engineering, Comp Sci, & Technology Homework 1
CIRCUIT ANALYSIS: Use superposition - 2 Current source, 1 Voltage source, 4 resistors Advanced Physics Homework 6
current to voltage conterter and voltage to current converter Engineering, Comp Sci, & Technology Homework 3
Kirchhoff Circuit: Current, Resistors, Voltage Introductory Physics Homework 9
