Thread Closed
Falling into BH question
Share Thread Thread Tools
Jan15-09, 04:16 PM   #69
Quote by Phrak View Post
By 'infalling', I hope you mean 1) matter that is present in the interior when the event horizon forms, or 2) exterior matter that will find itself within the horizon if the Swarzchild radius increases, for instance.
Presuming that it's possible to have "matter that is present in the interior <of an> event horizon" sort of bypasses the whole core of any discussion of whether it's possible to fall through an event horizon.
Jan15-09, 04:18 PM   #70
Quote by Chalnoth View Post
Naturally, yes. At least it would in the idealized black hole that was already fully-formed. If there is no singularity, apparently, there is no true event horizon.
Chalnoth
How are these things incompatible?
Why can you not have an event horizon (which isn't really a "thing" so much as a geometrical definition) if you don't have a singularity?
Thanks
Jan15-09, 04:20 PM   #71
Update on the falling into a realistic black hole with Hawking radiation:
My old GR professor got back to me, and pointed out something that I had forgot to consider: it depends upon whether or not a singularity forms before the black hole evaporates. If the singularity forms, then yes, some of the matter will travel in and smack the singularity before evaporation. If not, then indeed, infalling matter will see the black hole evaporate before it. Apparently the question as to whether or not the singularity will form in an evaporating black hole is still open.
Yes. I think that your old GR professor has described the problem nicely.
If an event horizon is something that anything can fall through, then it's inevitable that a singularity will form.
Jan15-09, 04:24 PM   #72
Recognitions:
Quote by MuggsMcGinnis View Post
Well, the issue is that there's no such thing as a black hole that hasn't formed from infalling matter. So if infalling matter can't form an event horizon in the first place, then clearly it's not going to make it to the singularity.
But if you already have a black hole sitting there, singularity and event horizon and all, then matter can most certainly fall through the event horizon.
Jan15-09, 04:49 PM   #73
Quote by xantox View Post
The photon emitted at the limit of the horizon will be received in infinite time measured by the distant observer, ie. never (supposing the purely classical case without evaporation). You're apparently considering this problem within special relativity, but that only allow to talk about flat spacetime with no gravity, where black holes do not exist indeed. I friendly recommend a reading of the beautiful and accessible introductory text by James Hartle, "Gravity: An Introduction to Einstein’s General Relativity", Addison Wesley (2002) (available on Amazon).
I was supposed to mean that in terms of the distant observer clock, the photons which he would expect to receive much sooner if the spacetime was flat, will be received much later. This is again a manifestation of spacetime curvature, not a modification of properties of light which always move locally at the speed of light c. That the travel time of light increases within a strong gravitational field is one of the classic tests of general relativity which has been confirmed experimentally with a precision of about 0.1%.
Got it! Thanks.
I don't know why I was being so dense on this... it would take longer than the 5.8 days for the light-pulse round-trip.
So, at what point in time will the distant observer be unable to receive a reflected return-pulse? If the reflective ball ("object") is tossed at the black hole at .5 c, from a distance of 2.9 light-days, then you're saying the object will have crossed the event horizon in less than 5.8 days (using an unaccelerated clock, stationary WRT the black hole). (correct?)
You're saying that, if the distant observer sends a light pulse 6 days after tossing the object, he will never receive a return pulse? The light pulse will pass through the event horizon, because there will be nothing for it to reflect from?
Jan15-09, 05:01 PM   #74
Quote by skeptic2 View Post
Naty1
I raised the question of how an object is able to cross the event horizon because I don't understand how it happens and what seems logical to me is at odds with the widely accepted interpretation of black hole geometries. Certainly I accept that observers in different reference frames don't always agree on observed time,distance,mass,etc. but I also believe that events in one reference frame can be mathematically transformed into any other reference frame to explain what those observers see. To suggest that simply because observers in different reference frames disagree about time, distance or mass, is sufficient reason to accept an ad hoc instance of differing observations without providing some sort of transformation between the reference frames is less than scientific.
I also raised the question hoping that someone here could point out the errors in my logic. The references I've seen, like xantox's posts, don't address the issue of the evaporation of the black hole during the extremely dilated time an object experiences as it falls towards the event horizon. Briefly put, is time infinitely dilated at the event horizon and if so, how does an object cross that event horizon in finite time? If it crosses in finite time in one frame of reference but not in another, what is the transformation between those reference frames that permits that?
skeptic2:
You and I are in the same place, on this.
I cannot (yet) see how two logically incompatible solutions can both be correct within any logically consistent system.
This requires that one problem has two correct solutions: BOTH (Yes = Falls through event horizion) AND (No = Does not fall through EH).
Doesn't this require that there is some statement, within the physical laws of our universe, for which "BOTH A AND NOT A" is true?
I'm not at all comfortable with that.
Jan15-09, 05:09 PM   #75
Your suspicions are valid for a test particle. A massive object that perturbs the event horizon may be different.
In addition to this, a central singularity is often invoked, but not proven nor motivated.
Using the contemporary view of what happens when things fall to black holes, the apparent velocity (with respect to the black hole) of an infalling particle approaches the speed of light.
Does this not yield a Relativistic mass increase?
Since the net mass of the system will be unchanged, wouldn't a considerable amount of energy (mass) be transferred from the black hole to every infalling object?
In fact, it seems (to me) entirely possible that all of the mass of the black hole would be transferred to the infalling matter surrounding the black hole.
I expect that xantox might have something to say about this.
Jan15-09, 05:23 PM   #76
Imagine you are halfway between two black holes that are approaching each other. To a observer the horizons merge, with you inside. Apparently the size of the black hole must increase for something to cross an event horizon--which, come to think about it, is nearly a tautalogy, anyway.
Why should it be dense? At the time of collapse, the mass is not all stuck at one point in space. Put enough air together at standard density and it's a blackhole.
The Schwarzschild metric relates radius to mass: R = M (2G/c2)
Since radius and mass are directly proportional, the mass density of a Schwarzschild black hole drops with radius. Density is proportional to R-2.
Interestingly, (according to the WMAP 5-year results) the mass density of a Schwarzschild black hole with a radius equal to that of the observable universe would equal the density of the observable universe.
In fact, our observable universe satisfies all requirements for a Schwarzschild black hole:
  • Spherically symmetrical
  • No electrical charge.
  • No spin.
  • R = M (2G/c2)
Wilkinson Microwave Anisotropy Probe:
http://map.gsfc.nasa.gov/universe/WMAP_Universe.pdf
Jan15-09, 10:32 PM   #77
Recognitions:
Basically there's no such thing in General Relativity of an object's velocity that is far away from the observer. Relative velocities are only well-defined if computed at the same point in space-time. You just can't subtract velocities at different points, so this sort of question is meaningless.
Furthermore, the idea of the relativistic mass is no longer used, as it leads to too many mistakes. This would be one of them, because the energy of the infalling object certainly does not diverge at it crosses the event horizon.
Jan15-09, 10:41 PM   #78
Recognitions:
Er, in a Schwarzschild black hole, all of the mass is located at the singularity in the center.
  • No spin.
  • R = M (2G/c2)
Actually the Schwarzschild radius of a black hole with the mass of everything within our current Hubble volume would only have a "radius" of about 1/4th of our Hubble volume (the R parameter of a black hole isn't actually a radius, but is directly related to the area of the event horizon...there is no well-defined radius, it turns out). So a black hole the size of our Hubble volume would be quite a bit more "dense", on average, than our universe.
Jan16-09, 04:49 AM   #79
Just in case anyone missed it, The Schwazschild metric applies to space without any matter in it. The Schwarzchild metric is equally applicable to the space around the Earth, for instance. It's just not applicable within the Earth itself. All that is required of it, is that the mass be mass be spherically symmetric and unchanging in qauantity over time.
There is nothing that requires the central mass to occupy a single point.
Jan16-09, 04:57 AM   #80
Not at all. The matter could be within the horizon at the time the horizon was created. Or it could be the result of a changing event horizon. Two blachholes merging in finite time would be an example.
A test particle, where by convention the mass of the test particle has no perturbative effect, is very small. It won't cross a static horizon.
Jan16-09, 05:03 AM   #81
I don't know where you are getting your facts. The velocities at assymtotic infinity are infinite in the reference frame of the horizon.
Jan16-09, 07:44 AM   #82
Recognitions:
Very true. The demand that everything at the center rests upon the observation of the propagation of light within the black hole: if even outgoing light rays emitted within the event horizon impact the center in a finite (and very short) time, then it is necessarily true that all matter will as well.
But as I said, this may not be the case for a realistic black hole if the horizon fails to form before it evaporates.
Jan16-09, 11:51 AM   #83
I'm not suggesting that the velocities of infalling objects would subtract, somehow, from each other. I'm suggesting that relativistic mass increase is inevitable for an infalling object.
Regarding "the idea of the relativistic mass is no longer used", perhaps I should refer to "momentum" or "energy"?
Jan16-09, 11:55 AM   #84
I apologize for any confusion, but, I don't refer to any reference frame at the horizon or within the horizon; only near the horizon or far from it.
The model I use is no less valid than the one Stephen Hawking used in lowering a box filled with thermal energy, via a rope, to the event horizon.
Jan16-09, 12:06 PM   #85
Recognitions:
Except you have to subtract the velocities for the relativistic mass to turn any different from its rest mass. If you're in the infalling object's frame of reference, after all, you consider your own velocity to be precisely zero.
Well, right. The proper way to compare it would be to look at the following:
1. What is the total energy of the particle very far away from the black hole?
2. What is the potential energy of a particle that falls from very far away to the event horizon?
Add the two and you get the mass-energy that is added to the black hole (assuming it's not spinning...things get a bit more interesting for spinning black holes).
Thread Closed
Thread Tools
Similar Threads for: Falling into BH question
Thread Forum Replies
Physics Falling Bodies Question Introductory Physics Homework 11
Question about gravity and falling General Physics 10
question on an object falling 10 m Introductory Physics Homework 13
Falling Ladder Question Introductory Physics Homework 3
Free Falling Question Advanced Physics Homework 1
