Is [a]^-1 = [0] if and only if p|a?
  • Thread starter Thread starter zoner7
    Law Proof
The discussion revolves around properties of congruence classes in the context of the field Zp, specifically examining the conditions under which the inverse of a congruence class exists and the implications of the prime p dividing a given element a.
  • Participants explore the relationship between the existence of the inverse of [a] and the divisibility of a by the prime p. Questions arise regarding the implications of a being non-zero and the reasoning behind p not dividing a.
Some participants provide insights into the reasoning expected in the original question, while others express uncertainty about specific assumptions and definitions. There is an acknowledgment that the original poster's approach was not incorrect, but lacked justification for the existence of the inverse.
Participants note the importance of understanding the properties of prime numbers and congruence classes, as well as the specific conditions under which the inverse of an element in Zp can be defined.
zoner7
in Zp, where a does not equal 0, that [a][x] = [a][y] is the same as [x] = [y].
This was a question on a test I just finished. Just curious how wrong my answer is. So I sort of ignored the congruence class part. I just said:
* [a]^-1 represents the inverse of [a] *
[a][x] = [a][y]
[a]^-1[a][x] = [a][y][a]^-1 (by associative law)
[1][x] = [1][y] (by the law of inverses)
[x] = [y] (since 1 is the identity element under multiplication in congruence classes).
so yea... did i do anything right?
thanks for the help in advance
At the very least mention why you think [a]-1 should exist. (it's non-zero). In fact, this is technically correct but I suspect more detail was expected (since if you know Zp is a field, this is a useless question). Here's how you probably were supposed to do it (I left two details to fill in)
[a][x] = [a][y] if and only if p|(ax-ay) if and only if p|a(x-y)
p|a(x-y) implies p|a or p|(x-y) (why?)
p does not divide a (why?)
Hence p|(x-y) and this gives [x]=[y]
and you can run the same thing backwards
EDIT TO ADD: I forgot to mention I'm assuming p is prime here, as otherwise the question's wrong
This is true, because since p is prime, we are able to apply Euclid's lemma.
I honestly couldn't tell you why p does not divide a.
so... did I do anything correct at all...?
Go back and read the question carefully... what do you know about a?
Nothing you did was wrong per se, it's just that you didn't support why there should exist a congruence class of the form [a]-1, which was probably what was expected of you (alternatively, and easier is the argument I posted).
/QUOTE]
ahh, got you.
A does not equal 0. but why does that mean that p cannot divide a. any prime p divides into 0.
By definition
[a] = [0] if and only if p|a
  • · Replies 19 ·
