Does the Delayed Choice Experiment Challenge Classical Intuition?
  • Context: Graduate
  • Thread starter Thread starter debra
    Choice Delayed choice
The Delayed Choice Experiment, as revisited in this discussion, illustrates the fundamental principles of quantum mechanics, particularly through Wheeler's framework. When an observer decides to measure a photon as a wave or a particle, the outcome is influenced by the observer's choice, demonstrating the concept of wave-particle duality. The Copenhagen Interpretation clarifies that a wave packet exists in superposition until an interaction occurs, leading to decoherence and the collapse of the wave function. Ultimately, the results of the experiment depend on the observer's decision at the receiving end, emphasizing the role of observation in determining quantum behavior.
  • Understanding of quantum mechanics principles
  • Familiarity with the Copenhagen Interpretation
  • Knowledge of wave-particle duality
  • Concept of wave function collapse
  • Research the implications of the Copenhagen Interpretation in quantum mechanics
  • Explore the concept of superposition in quantum systems
  • Study the phenomenon of decoherence in quantum physics
  • Investigate other interpretations of quantum mechanics, such as Many-Worlds Theory
Physicists, quantum mechanics students, and anyone interested in the philosophical implications of observation in quantum experiments.
debra
Delayed Choice Revisited.
Here is a very cut down summary of Wheeler's delayed choice experiment (hope I got it essentially correct):
When a wave packet is half way between the screen and the double slits, a decision is made by the observer as to whether to look for a photon or a wave.
If a wave is chosen to observe, then its intensity is due to the interference between the two paths from the slit - no problems.
If the particle is chosen to observe, by essentially looking directly down both paths to the two slits, then a photon is indeed observed, which went down just one slit path as only a particle can do - no problems.
The confusion, is caused, by the conflict between a particle going along a fixed single path, and a wave which 'must have been' in two paths at once. It appears as a contradiction.
But using Copenhagen Interpretation, there is no contradiction because a wave packet is neither a wave or a particle, only a probability of observing one or the other. Only if the wave packet *interacts* with something on the way will decoherence take place. If it does not interact there is nothing to say what happened on the way, because on the way the position and momentum remain unobserved - in superposition.
It was a wave packet that made the journey, and that would have been in both paths at once!
Then if a particle was observed that is the result of probability (wf collapse) at the receiving end.
Likewise, the interference wave result is also the result of summation of wave amplitudes at the receiving end for waves in both paths.
So no matter what was chosen to observe, the result was due to the wave packet that made the journey, and more importantly, the result was determined upon arrival. The delayed choice of whether to observe a particle or a wave at the receiving end is actually the same as the decision whether to interact with the wave packet on its journey - and this decides whether decoherence has taken place or not. This delayed choice also determines whether the wave packet behaves like a wave (no interaction) or a particle (interaction) when it reaches the double slits.
  • · Replies 58 ·
  • · Replies 24 ·
  • · Replies 157 ·
17K
