Thread Closed
Flywheel Generator - Split from Propane Solar Collector/Generator Thread
Share Thread Thread Tools
Nov29-08, 01:14 AM   #1
I have been working on a holistic system involving flywheel-generators and methane gas as the power source. With all of the recent publicity given methane as a potential source of energy I figured that this was the way to go. I have some rudimentary drawings of the whole system and all of the materials should be readily available off of the shelf as is a basic requirement of all Anticipatory Design Scientists. (Buckminster Fuller). I'd love some feed back on the idea.
Basically it is a perpetual motion machine as are all machines when they have all inputs inplace. The Earth is a regenerative system and nothing operates outside of the rules of local universe. In this idea we use a vacuum mounted flywheel which should keep increasing in speed if we apply a constant influx of methane. The methane will be around as long as the animals that feed the anaerobic digester are around and the electricity will increase in amount as the flywheel-generator increases in speed. The following is a link to a picture http://api.ning.com/files/z23LVafEV*...425&height=313
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Nov29-08, 05:08 AM   #2
Recognitions:
Gold Membership Gold Member
Greatglory, this is not a new idea, and many thousands of megawatts of electricity are currently being produced from human and agricultural waste. Perhaps you should look into the (very large) market of biogas power generation, where methane from anaerobic digesters (from sewage and farm waste) is burnt in a gas engine, with the resulting waste heat being used to warm the digesters. The only difference between this and your idea is that a reciprocating engine is used for high efficiencies, control, and heat recovery.
I would also advise you avoid using the term "perpetual motion machine", this is the talk of crackpots and lunatics and will attract undeserved attention from moderators.
Nov29-08, 11:27 AM   #3
Mentor
One thing though - I don't see what purpose the flywheel serves and it seems to me that you may think it is doing more than it really is: Flywheels only store energy, they cannot perpetually generate it.
Nov30-08, 05:47 AM   #4
It seems to me that if something can store energy (ie flywheel) and if it is given a constant input of new energy it is doing something that actually helps in the overall process of energy creation. My thinking is that a small engine attached to a very large flywheel will create a lot of energy. Especially if you start the flywheel off slowly and allow it to increase in speed exponetially.
As for the fact that methane is used to produce energy already of this I am totally aware. My innovation is in using a specific type of anaerobic digester made in China by a Puxin Technolgies Corporation and linking it to a special collector of the animal manure that I call a S*it bag. These S*it bags ideally will be made of Hemp and ultimately act as Silage for the digester improving the overall production of the total system.
If you could do me the favor please check your math on the ability of a flywheel that is suspended in a vacuum to create energy if given a constant input of new energy. It is my opinion that you will find that not only can it produce energy but the amount of energy it will produce will be phenomenal. (Note: one must be able to have a free spinning turbine attached to the flywheel as opposed to an internal combustion engine).
Nov30-08, 06:26 AM   #5
Recognitions:
Quote by greatglory View Post
No, this is not the case. The flywheel will only allow you to extract the amount of energy you put in with your small engine (minus a bit for frictional losses in the bearings). The flywheel can store an amount of energy, but it will never be more than you put in with the small engine in the first place.
It's you who needs to check your maths (and understanding of basic thermodynamics) here. As Russ has already advised, a flywheel cannot 'produce' energy; only store it. You could run your engine for a year, and store lots of energy in the flywheel over a long period of time and recover this energy in a short period of time; but you'll never be able to get out of it more energy than you put in. The source (reciprocating engine, turbine, hamster wheel) is irrelevant here other than for practical considerations. End of story.
Nov30-08, 07:38 AM   #6
Quote by brewnog View Post
In my original post I mentioned that the flywheel was in a vacuum much as is outer space and that the engine was to be on constantly. Those who played the lunar landing games of the 1980's will remember that a burn accelerates the craft while a non-burn keeps it moving at the same speed. If when you apply a constant burn to a flywheel it keeps accelerating is not that the same as creating energy? Unless your arguement is that there will be no acceleration. Nor for that matter constant acceleration.
Forget if you will for a moment all LAWS and think about what I am saying. No new innovations have ever come about by men constrained in another man's law.
Nov30-08, 07:39 AM   #7
Newton's Second Law
The second law is sometimes called the Law of Dynamics, because it concerns forces and what causes objects to move. It can be stated as:
The acceleration of an object of constant mass is proportional to the force acting upon it.
Acceleration is the changing of the velocity of the object. Usually, we are talking about the object speeding up. The word "deceleration" is usually used when the object is slowing down, but that also is acceleration or changing of the velocity.
A force is a push or pull on the object. It may pushing in direct contact or pulling at a distance in the case of gravity.
This law determines the relationship between force, mass and acceleration, which is
F = ma
where:
F is the applied force
m is the constant mass
a is the resulting acceleration
ma is m times a
Note that the force F and acceleration a are in the same direction. Since they have a direction, they are called vectors.
What this law says is that while you are applying a force on an object, it will continue to accelerate or change its velocity. It also states that the greater the force on an object, the greater the acceleration.
Nov30-08, 07:44 AM   #8
There I've checked my maths and in fact if Newton's second law is correct, so am I. A flywheel operating in a vacuum will in fact continue to increase in speed as long as a constant amount of energy (force) is applied to the system. This increase in speed can be harnessed to create increasing amounts of energy from the engine and that is why it as crucial that the engine not be limited in speed as are internal combustion engines.
Nov30-08, 09:39 AM   #9
Mentor
Heh. No and no.
Correct. But that tells you nothing at all about extracting energy from a flywheel (well, you could extrapolate...).
That part is true.
This increase in speed can be harnessed to create increasing amounts of energy...
That part is not.
You seem to understand how to accelerate a flywheel. What you don't understand is how to extract energy from a flywheel. Here's a hint: they are the same process, with one minor difference: a minus sign.
Nov30-08, 10:14 AM   #10
Quote by russ_watters View Post
Heh. No and no. Correct. But that tells you nothing at all about extracting energy from a flywheel (well, you could extrapolate...). That part is true. That part is not.
Actually I do know how to extract energy from a flywheel. Remember, there are two parts to the system a flywheel and a generator that are linked together. Correct me if I am wrong. As a generator increases in speed it can produce increasing amounts of electricity. That is the beauty of this system. It will produce increasing amounts of electrical energy ad infinitum.
Nov30-08, 10:34 AM   #11
Mentor
You are incorrect. A generator produces energy by converting mechanical energy to electrical. This requires both an rpm and a torque. The torque is the part you are missing. Heck, if generating electricity required no torque, we could just generate an arbitrarily large amount by gearing-up our generators.
Nov30-08, 10:38 AM   #12
Recognitions:
Ok. You are wrong.
It won't produce increasing amounts of energy. It will store increasing amounts of energy. If you take this energy out of the flywheel to produce electricity, it will slow down, and be storing less energy.
Let me repeat this one last time.
The flywheel is only a store of energy. You will always get less energy out of the flywheel than you put in; never more.
Your argument about ignoring scientific laws and facts shows a complete lack of understanding or appreciation of the most basic physical concepts. Go and read a book and learn something before you try and propogate nonsense.
Nov30-08, 11:02 AM   #13
You are at best arguing semantics here and at worst just trying to save face. If it STORES INCREASING AMOUNTS OF ENERGY Then you can get ever increasing amounts of energy out of it. What has you so upset? It should be obvious to everyone else that a flywheel-generator combination that is increasing in speed will produce more and more electricity. I don't appreciate the insults especially when I am correct in this matter. Finally, what I was saying about ignoring laws is particularly applicable in this case as I came to my conclusions without knowing about Newton's second law but there it was to back me up. Please provide your math. I provided mine.
By the way an actual flywheel generator already exists that meets all of the requirements of my system only as of now it may be being made from materials that will shatter when it gets up to top speed. New materials may be in order and it has to be linked to a methane gas turbine to provide unlimited inputs.
Nov30-08, 11:34 AM   #14
The torque is provided by the flywheel that is attached directly to the generator. And yes, you've finally hit the nail on the head. Were we to attach a flywheel to ALL our generators we could produce and arbitrarily large amount of electricity.
Nov30-08, 11:34 AM   #15
Recognitions:
Cobblers. At best I'm trying to teach you some science, and at worst dispairing at someone who's come here under the guise of asking for advice, with the intent of propogating nonsense and ignoring the facts.
No. It can't increase in speed AND output energy. If it's increasing in speed, that's because it's storing energy and not producing energy. As soon as you take energy out of the flywheel (to produce electricity, for instance), the flywheel slows down!
Here you go. I think the Wikipedia page will sum it up at an appropriate level, assuming you don't fancy reading any thermodynamics texts.
http://en.wikipedia.org/wiki/Laws_of_thermodynamics
The bit about "for a thermodynamic cycle the sum of net heat supplied to the system and the net work done by the system is equal to zero" is most interesting.
Nov30-08, 11:36 AM   #16
Recognitions:
For your information, every mechanical/electrical generator has a flywheel on it. This has nothing to do with producing more power (and it doesn't), it just stabilises the output of the generator and assists with transient and steady state control.
Nov30-08, 01:56 PM   #17
Mentor
You're still missing the point. Why do you suppose that the flywheel can apply a torque to a generator without slowing down?
Why would you assume that something so obvious could be overlooked by so many millions of scientists and engineers? Consider the more likely scenario: that you have a misunderstanding of this basic issue of flywheel operation. Consider also that you are not the first person to have this exact misunderstanding and post about it in this forum.
What you provided should make it clear to you why you are wrong: to make it accelerate, you apply a force. To make it generate electricity, it must apply a force and will therefore decelerate.
But also, that's not much in the way of math that you've looked into on the subject. Please look into the math of flywheel operation in the wiki page for it: http://en.wikipedia.org/wiki/Flywheel and also the wiki for angular acceleration: http://en.wikipedia.org/wiki/Angular_acceleration
It would probably be helpful if you did some math - by that I mean an actual hypothetical calculation of the performance of your proposed device, because it would highlight your error and help you understand it. Try picking an arbitrary size for a flywheel and do the math to figure out how much energy it takes to accelerate it to a certain rpm and how much power you can extract from it without making it decelerate. And pay particular attention to the difference between the concepts of power and energy.
By the way an actual flywheel generator already exists that meets all of the requirements of my system...
Except that it says right there in the first sentence of the page that it is a UPS (a battery), not a generator. It stores energy, it doesn't continuously generate it.
Thread Closed
Thread Tools
Similar Threads for: Flywheel Generator - Split from Propane Solar Collector/Generator Thread
Thread Forum Replies
Air driven turbine for generator and flywheel? Mechanical Engineering 4
Propane driven Generator system Mechanical Engineering 39
Solar collector concerns General Discussion 18
New solar collector from 12-year-old Electrical Engineering 4
Anyone thought of combining solar water heater with Stirling generator? General Engineering 11
