Solid Mystery: A Non-Conductor of Heat, Yet a Good Conductor of Electricity?
  • Context: High School
  • Thread starter Thread starter myaqub
    Conductor
The discussion revolves around identifying a solid material that is a good conductor of electricity but a poor conductor of heat. Participants explore the implications of this question in the context of a scientific project involving water decomposition.
  • One participant seeks a solid that conducts electricity well but poorly conducts heat, suggesting this is crucial for a scientific breakthrough.
  • Another participant argues that typically good electrical conductors also conduct heat well, citing the Wiedeman-Franz ratio.
  • A different viewpoint mentions that while good thermal conductors exist that are poor electrical conductors (like diamond), the specific requirements of "easily available" complicate the search.
  • One participant suggests carbon as a potential candidate, noting its flexibility despite not being the best conductor of either electricity or heat.
  • Further discussion reveals the participant's goal is to decompose water without boiling it, which is hindered by high temperatures at the electrodes.
  • Another participant provides insights on voltage and amperage requirements for hydrogen production, indicating that the project has been attempted before.
Participants express differing views on the feasibility of finding a solid that meets the criteria. There is no consensus on a specific material, and the discussion remains unresolved regarding the best approach to the problem.
Participants note the importance of specifying quantities for "good" and "bad" conductivity, as well as the challenges posed by the requirement for the material to be easily available. The discussion also highlights the complexity of the relationship between electrical and thermal conductivity.
This discussion may be of interest to those exploring materials science, electrical engineering, and chemistry, particularly in the context of electrolysis and hydrogen production.
myaqub
Good conductor Of Electricity
Can anyone help me by answeing the following question :-
"Please name a Solid which is good condcutor of Electricity, but is a non-conductor or at least a bad conductor of heat? and is easily available."
In the context of the above question I may add that I am at the verge of a major scientific breakthrough, in the way of which only one hurdle lies which you may deduct from my question.
in all cases I can think of a good electrical conductor is a good thermal conductor. electrons not only conduct electricity but due to their interaction with atoms in a lattice structure conduct heat as well.
It's easier to fing the opposite - good thermal conductors that are poor electrical conductors, like diamond. If you didn't add "and is easily available" I would have suggested some High Tc Superconductor. These conduct electricity beatifully, but only do an average job with heat - and that's at about 50K. If you hadn't said "solid" then there's several liquids that work nicely, including sea water.
Clearly, you won't find a solution among conventional metals as they would obey the Wiedeman-Franz ratio. There may be something exotic out there that works. There may also be a simple solution that is avoiding me.
Could you give us a glimpse into where this is leading ? That may help. And unless you specify quantities for "good" and "bad" it's hard to tell exactly what you need. For instance, if you say electrical resistance needs to be at most 10^-6 ohm-cm (this is not great compared to metals like copper and silver which are 10^-8 but much better than semiconductors like silicon or germanium, which are about 10^-3 only) and thermal conductivity must be below 50 W/m-K (this is only poor compared to copper and silver which are about 400W/m-K, most other metals are also above 100W/m-K...but glass is about 1 W/m-K and wood is like 0.1 W/m-K) there there are a few phosphor bronzes that will work. If you make the requirement any stricter, it becomes difficult to find anything.
Maybe something in between like Carbon. Not the best conductor of either but can be shaped/sized to give you a lots of flexability.
Regards
My purpose
Thanks to everyone who took time to reply to my query.
Well what I am trying to do is to decompose water, but in that process the temperature of electrodes goes so high that the water starts boiling and that is the main glitch in my project. What I want is that the water should not become steam, instead it should decompose into its two main components i.e Oxygen and Hydrogen.
And I can't use low voltage because I want to produce hydrogen in very large quantities in short time.
you only need about 2.2volts for your hydrogen cell the main component is amperage low V high A. and by the way been done before. the path you walk is well and truly deeply rutted LOL
I bet he's figured this out since it's been over 5 years now.
... or he graduated!
thanks guys.i forgot to look at the date and when i did i though what a dork i am. maybe he has graduated and invented the hydrogen supper cell and making squillions. thanks lol
  • · Replies 0 ·
  • · Replies 88 ·
11K
  • · Replies 152 ·
12K
