Troubleshooting a Newly Built PC: No Display
The discussion revolves around troubleshooting a newly built PC that is experiencing no display issues during startup. Participants explore various potential causes and solutions related to hardware components, particularly focusing on the graphics card, memory, and motherboard settings.
  • One participant describes the symptoms of their newly built PC, noting that it powers on with fans running and a post beep, but no display appears on the monitor.
  • Another participant suggests disconnecting nonessential components and checking jumper settings on the motherboard to isolate the issue.
  • A participant reports intermittent long beeps indicating "missing memory" after disconnecting other components and adjusting memory slots.
  • There is a discussion about whether dual-channel memory configuration is necessary and how to properly set the front-side bus (FSB) speed for the memory.
  • Some participants propose testing the system with only one memory stick to rule out defective memory or BIOS settings affecting dual-channel operation.
  • Concerns are raised about the reliability of the graphics card, with one participant sharing experiences of video cards failing to work with certain motherboards.
  • Another participant expresses confusion over whether the graphics card could prevent the PC from posting and questions the nature of the beep sounds being heard.
  • One participant shares a method of resetting the CMOS settings as a potential troubleshooting step.
  • A later reply indicates a decision to replace the graphics card after trying various troubleshooting steps without success.
Participants do not reach a consensus on the exact cause of the issue, as multiple potential problems are discussed, including the graphics card, memory configuration, and motherboard settings. The discussion remains unresolved with various competing views on the troubleshooting steps.
Limitations include uncertainty regarding the functionality of the graphics card, the necessity of dual-channel memory, and the impact of specific motherboard settings on the system's ability to post.
wolram
Dearly Missed
i have finished building pc and spent two days attempting
to sort out this problem, when i start pc fans work i get
a post beep "more like a click", but nothing on monitor,
i don't get error beeps, i have reseated the graphics card,
checked all connections, the mobo led lights up ok, i have
swapped memory slots, when i do this i get error beep
so i guess mb is working, the dvd light comes on .
i only have monitor key board plugged in.
i have asus a7n8x-x mb
2 sticks 512mb pc2100 266ddr dim mem
amd k7 athlon xp 2500 plus 333 fsb
256mb galaxy fx5200 8x agp tv out dvi
can anyone help please.
Computer science news on Phys.org
I would disconnect all nonessential components and then look to see whether the monitor displays anything as the computer runs through the POST. You need to see something here before adding other peripherals, and adding those items one at a time can often locate the component that is introducing problems. Insure you have any necessary jumper connections set to their proper positions on the motherboard (CMOS clearing, etc.) then give it another try. If you are able to see the POST then you should be able to enter the BIOS and make other adjustments as needed.
Good luck
Thanks BoulderHead,
i have disconected hard drive, flopy and dvd, so all
i have now is graphics card, keyboard and monitor
pluged in, now "sometimes", when i power up i get
long regular beep, "missing memmory", i have swaped
memmory from slot 1 and 3 to 1 and 2 but it still the
same, i have checked jumpers and all are on default,
the only one that seems to matter is the cemos,
im not sure about cpu i have a choise of fsb 200
or 400/333/266.
i have just cheked 400/333/266 is the setting for that jumper,
now I am lost.
Have you tried to boot using only one of the memory sticks?
I would imagine slot 1 is where it would go, and I would try first one stick, then the other.
[edit]
400/333/266 is the choice to select for fsb speed, as your memory will be running at 266MHz.
Yes i have tried slot 1 and slot 3 and get the same beep code
as this board is dule channel ,"supposedly", i guess i have to have
2 slots filled ,1 and 3 are suggested at some web sites, "its not
in the manual", thing i don't understand is why its only sometimes
i get this warning.
No, I doubt that two sticks are required to operate with. There may be a setting in the BIOS to enable the Dual-Channel feature, I dunno. What I'm suggesting is to attempt starting the system using only one stick (inserted into channel 1) and if it doesn't help to turn off the power, swap sticks, and try it again.
My thinking is two-fold; rule out the possibility one of the sticks is defective, and rule out the possibility of some BIOS setting reacting negatively to having both sticks inserted at the same time.
Also, I have seen a brand new video card (ATI) not work with one motherboard, yet work fine with another. There were no setting to be adjusted anywhere that would make the system work. That, combined with other experiences leads me to conclude that video cards are fickle, and not to be automatically ruled out as a source of trouble. If you have another card, even an old 1MB card, I'd give it a try.
just tried both sticks in slot 1 and its still the same
i cheked to see what happens starting with all slots
empty and i get imediate warning, so i guess its a
dirty rotten low down fickle video card, and i dont
have a replacement to try, oh well
Sorry I don't know of anything else to suggest, but perhaps another member can.
Good luck
When you think it's the vid card, it probably is, but it could also be something in the motherboard on the vid card slot, or the monitor.
Oh, do you have on-board video, and if so, do you have it disabled properly?
Njorl
Hi Njorl.
no this board has no "onboard ", graphics, i am swapping
the monitor between this pc and my new one so i know
it works, the fan is working on the vid card but i dont
suppose that means much, since i disconnected all
but KB,Monitor and graphics card i haven't had a post
tone, this is confusing me, as i don't know if graphics
card can cause pc not to post, or even if the noise
i get is a post tone, its more of a melodious click
whereas error tones are a clear note.
Thanks for your help BoulderHead, i did expect problems
before i started this build, having read many horror stories
but it will be solved eventualy.
You're welcome. Something that came to mind is that I have seen more than just one or two new motherboards give problems to get going. Sometimes I could get a system up by disconnecting the power cord to the supply (because modern power supplies continue to output +5V even when the computer is ostensibly turned off), then removing the CMOS battery for a couple of minutes. This is a sure way to clear the CMOS settings back to factory defaults. Following that, put back the battery and power cord where they belong and try once more to boot the computer using only one of the memory sticks.
If that doesn't work, I'd be thinking real hard about getting my hands on another video card.
OK i have tried everything, so its a replacement vid card
i can get a G force one for a reasonable price, no tv out
but what the heck who watches tv, and my wallet is
getting anorexic thanks for help.
  • · Replies 19 ·
  • · Replies 21 ·
