Energy required to expand V of cylinder
  • Thread starter Thread starter vertciel
    Cylinder Energy
The work done when the volume of a cylinder is increased by 90.0 L against atmospheric pressure is calculated to be 9,117 Joules (J). The conversion from liters to cubic meters is essential, where 90.0 L equals 0.0900 m³. The pressure used in the calculation is 1.013 x 10^5 Pascals (Pa), which is equivalent to 1.013 x 10^5 Newtons per square meter (N/m²). The final result confirms the accuracy of the calculation using unit analysis.
  • Understanding of unit conversions, specifically from liters to cubic meters.
  • Basic knowledge of pressure units, particularly Pascals (Pa).
  • Familiarity with the concept of work in physics, defined as force multiplied by distance.
  • Ability to perform calculations involving pressure and volume in thermodynamics.
  • Study the principles of thermodynamics, focusing on work done by gases.
  • Learn about the Ideal Gas Law and its applications in calculating work.
  • Explore the concept of pressure-volume work in isothermal and adiabatic processes.
  • Investigate the relationship between work, energy, and heat transfer in thermodynamic systems.
AP Chemistry students, physics students, and anyone interested in understanding the calculations related to work done in thermodynamic processes involving gases.
vertciel
Calculate the work done when the volume of a cylinder is increased by 90.0 L against the atmospheric pressure. Think about the upward movement of a piston as it expands the volume of a cylinder.
I am actually an AP Chemistry student and am supposed to do this problem using unit analysis as I am not taking AP Physics. However, I have taken Grade 11 Physics.
Thank you for your help!
My Work:
Since 1 L = 0.001 m3, then 90.0 L = 0.0900 m3.
Since 1 Pa = 1 N/m2, then 1.013E5 Pa = 1.013E5 N/m2.
In order to get Nm = J = work:
1.013E5 N/m2 x 0.0900 m3 = 9,117 Nm = 9117 J = 9.12 x 103 J.
That looks correct.
Thank you for your response!
  • · Replies 67 ·
15K
