Finding mass of a central body: centripetal forces and orbiting bodies
The discussion focuses on calculating the mass of the star Epsilon Eridani using centripetal and gravitational forces. The mass is derived from the orbital characteristics of its planet, which has a semi-major axis of 3.39 AU and an orbital period of 6.54 years. The calculated mass of Epsilon Eridani is approximately 0.901 solar masses (Ms), but precision adjustments using more accurate constants yield values closer to 0.911 Ms and 0.919 Ms. Participants emphasize the importance of using precise values for constants and maintaining accuracy throughout calculations.
  • Understanding of centripetal and gravitational forces
  • Familiarity with orbital mechanics and Kepler's laws
  • Knowledge of physical constants such as gravitational constant (G) and solar mass
  • Ability to perform unit conversions (e.g., AU to meters, years to seconds)
  • Research the gravitational constant (G) and its significance in astrophysics
  • Learn about Kepler's laws of planetary motion and their applications
  • Study the impact of precision in scientific calculations and error propagation
  • Explore the methods for calculating stellar masses using different astronomical units
Astronomy students, astrophysicists, and educators involved in teaching orbital mechanics and gravitational physics will benefit from this discussion.
Omnistegan
One stellar mass is defined as the mass of our sun (1Ms = 1.99 x 1030 kg). ONe astronomical unit is defined as the length of Earth's semi-major axis (1AU = 1.49 x 1011 m). The star Epsilon Eridani in the constellation Eridanus has a planet (discovered in 2000) orbiting it that has a semi-major axis of 3.39 AU. The orbital period of the planet is 6.54 years. Based on this information, determine the mass of Epsilon Eridani in stellar masses (Ms).
[tex]F_{c} = F_{g}[/tex]
[tex]F_{c} = \frac{4\pi^2r}{T^2}[/tex]
[tex]F_{g} = \frac{Gm_{1}m_{2}}{r^2}[/tex]
mp is the mass of the planet, me is the mass of Epsilon Eridani
[tex]\frac{4\pi^2m_{p}r}{T^2} = \frac{Gm_{p}m_{e}}{r^2}[/tex]
Solve for me, the mp's cancel
[tex]m_{e} = \frac{4\pi^2r^3}{T^2G} = \frac{4\pi^2\left(3.39 \times 1.49\times 10^{11}\right)^3}{\left(6.54 \times 365 \times 24 \times 3600\right)\left(6.67\times 10^{-11}\right)} = 1.79 \times 10^{30}[/tex]
now divide that answer by kg in a Stellar Mass
[tex]\frac{1.79 \times 10^{30}}{1.99 \times 10^{30}} = 0.901M_{s}[/tex]
Apparently the correct answer is 0.903Ms. I did have a chance to clarify with my teacher that 365x24x3600 is what he expected us to use for seconds.
Any help is appreciated!
And you need to calculate this exactly?
Within .2% of the answer is not acceptable, even with the precision given in the problem?
I agree with LowlyPion here.
BTW, if you want to be precise, you should have used 1 year = 365.242 days, 1 solar mass = 1.98892×1030 kilogram, 1 AU = 1.49598×1011 meters.
However, this will give 0.911 solar masses as the final answer.
If you simply substitute 1.50e11 meters for the length of 1 AU for your value of 1.49e11 meters yields a final answer of 0.919 solar masses. Note well: 1.50e11 meters is a better 3-digit value for the length of 1 AU than is 1.49e11 meters.So what is going on?
(1) Just because you only know some values to 3 digits does not mean you should truncate everything to 3 digits. It is far better to represent physical constants to their full accuracy and truncate the final result to the expected accuracy (e.g., three digits in this case).
(2) A long sequence of products and ratios involving approximate numbers can (will) reduce the accuracy of your final result.
(3)Raising approximate numbers to powers can (will) reduce the accuracy of your final result.
  • · Replies 27 ·
  • · Replies 40 ·
