Graphing Slope Fields: A Calculator-Free Guide
  • Context: Undergrad
  • Thread starter Thread starter abacus
    Fields Graphing Slope
This discussion provides a comprehensive guide on graphing slope fields for differential equations without the use of a calculator. The primary examples discussed are dy/dt = t^2 - t and dy/dt = y^2. Key steps include selecting a range of (t, y) points, calculating the slope at each point using the given equations, and drawing short line segments to represent these slopes. By connecting these segments, one can create an informative slope field that visually represents the behavior of the differential equations.
  • Understanding of differential equations, specifically the form dy/dt = f(t, y)
  • Familiarity with plotting points on a Cartesian coordinate system
  • Basic knowledge of slope and its graphical representation
  • Ability to perform algebraic calculations for specific values of t and y
  • Learn how to graph slope fields for more complex differential equations
  • Explore the concept of direction fields and their applications in differential equations
  • Study the qualitative behavior of solutions to differential equations
  • Practice using software tools like Desmos or GeoGebra for visualizing slope fields
Students studying calculus, educators teaching differential equations, and anyone interested in visualizing mathematical concepts related to slope fields.
abacus
I'm still having trouble with figuring out slope fields.
If I have a function dy/dt= f(t,y), how would I go about graphing the slope field for my solutions without the use of a calculator.
An example would be how would I graph the slope field of dy/dt = t^2-t and dy/dt = y^2? Thanks.
Choose a number of (t,y) points on your graph. Calculate f(t,y) for each of those. Draw a short line through (t,y) with slope f(t,y).
For example, at (1,1) with dy/dt= t2- t, dy/dt= 0 so we draw a horizontal line- in fact, since y is not explicitely in that formula, it is obvious that dy/dt= 0 for all points on the vertical line t=1. At each point on that line, draw a short horizontal line. At t= 0.5, t2= .25-.5= -.25 so at every point on the vertical line t= 0.5, draw a short line with slope -.25. Try to connect those to the lines at t= 1.
For dy/dt= y2, since t does not appear explicitely, you can calculate y2 for each y and draw short lines with that slope all along the horizontal line at y.
Graphing slope fields can seem intimidating at first, but with a few key steps, you can easily create accurate and informative graphs without the use of a calculator.
First, let's break down the given example of dy/dt = t^2-t and dy/dt = y^2. The first step is to identify the variables in the equation. In this case, we have t and y as our independent and dependent variables, respectively.
Next, we need to plot a few points on our graph to represent different values of t and y. For example, we can choose values such as t = -2, -1, 0, 1, 2 and y = -2, -1, 0, 1, 2. This will help us visualize the behavior of the slope at different points on the graph.
Now, we can use the given equations to calculate the slope at each of these points. For the first equation, dy/dt = t^2-t, we can substitute the values of t and y to get the slope at each point. For instance, at t = -2 and y = 1, the slope would be (-2)^2-(-2) = 6. Similarly, we can calculate the slope for the other points.
Once we have calculated the slope for each point, we can plot them on our graph. For example, at t = -2 and y = 1, we would plot a small line segment with a slope of 6. We can repeat this process for all the other points we plotted earlier.
By connecting these line segments, we can create a slope field that represents the behavior of the slope at different points on the graph. The slope field for the equation dy/dt = t^2-t would look something like this:
[Insert slope field graph here]
The same process can be followed for the second equation, dy/dt = y^2. We would plot points with different values of t and y, calculate the slope at each point, and then connect them to create a slope field.
I hope this explanation helps you understand how to graph slope fields without a calculator. Remember to choose a variety of points to get a better understanding of the overall behavior of the slope. Practice makes perfect, so keep trying and don't hesitate to ask for help if needed. Best of luck!
  • · Replies 16 ·
  • · Replies 21 ·
