| Thread Closed |
Calculate lattice constant from x-rays |
Share Thread | Thread Tools |
| Dec7-08, 02:26 AM | #1 |
When x-rays are diffracted off NaCl, constructive interference is observed at an angle of 16.3 degrees. Determine the lattice constant of NaCl. Frequency of the X-ray is 1.948 x 10^18 hz Theta = 16.3 degrees 2. Relevant equations (As far as what we're told to use and what's in the book) 2d * Sin (Theta) = m * Lambda 3. The attempt at a solution After looking through the problem it is very clear that I am unable to find the "lattice constant" from the information given in the book. I've found the following equations: 1) d = a/sqrt(h2+k2+l2) 2) Lambda/2a= sin 2 Theta/h2+k2+l2 I've tried deriving #2 down to where it is usable and I get: a2 = (Lambda2/4) * (h2+k2+l2/Sin2 Theta) I've been unable to figure out what the miller indices are (h k and l), but everything I've tried doesn't get anywhere near the values expected online of 5.63-5.65. Am I going about this completely wrong or am I just overthinking the problem? Any help would be much appreciated. |
| Dec8-08, 02:14 AM | #2 |
Recognitions:
I don't think you can figure out the Miller indices if you don't know the orientation of the crystal anyway, right? (It's been a while since I took solid state.)
EDIT: I don't get 5.63 (Angstoms?) either (for any value of m). |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Calculate lattice constant from x-rays
| Lattice Constant | Advanced Physics Homework | 20 | ||
| How do you calculate the lattice parameters c and a of Hexagonal ZnO | Atomic, Solid State, Comp. Physics | 7 | ||
| Difference between bond length and lattice constant | Chemistry | 1 | ||
| Lattice constant of martensite? | Atomic, Solid State, Comp. Physics | 2 | ||
| Calculate the lattice constant of a body-centered cubic iron | Advanced Physics Homework | 1 | ||
