The Dividing Universe
by lubuntu
Tags: dividing, universe
lubuntu
lubuntu is offline
#1
Dec8-08, 10:56 AM
P: 473
I have no idea of the math behind this idea but I thought it was interesting to think about.
Say we have a universe like our own in that,and that the following are true:
a.Galaxy that are not close enough to have strong gravitational force to each other are moving away from eachother at an expanding rate.
b. In some distant time, the clumps of galaxies are so far apart that the acceleration seems to exceed c, ei. that light can no longer be seen of other galaxy clusters, therefore only an observer could only know of there own galaxy cluster.
c. Eventually, gravity overcomes the matter and space in the area is contracted to a singularity.
Little Bang
Could the universe just simple continue dividing itself it smaller and smaller clumps of matter?
I see a few problems with this of course. That the big bang was an explosion of space not in space. But it it possible perhaps that within a larger universe a portion of it is contracted to a singularity, or does that not make sense?
Phys.Org News Partner Space news on Phys.org
First-of-its-kind NASA space-weather project
Some astronauts at risk for cognitive impairment, animal studies suggest
Spacewalking astronauts complete urgent repair job (Update)
TalonD
TalonD is offline
#2
Dec8-08, 02:49 PM
P: 177
interesting idea, given enough time a gravitationally bound cluster of galaxies might colapse under their own gravity and form a supermasive black hole? is that a possible scenario for the future of the universe?
m36bayarea
m36bayarea is offline
#3
Mar19-09, 01:45 PM
P: 12
If universe continue expand at accelerating rate then galaxies will be far enough and gravity between galaxies too weak to pull it together again. Therefore, galaxies will get bigger and bigger and then gravity of individual galaxies win and pull matter back to massive black hole and singularity. We may have millions of universes rather one. Each galaxy will become an independent universe. With this theory there may be infinite number of universe already and we are just adding more and more to it.
Ich
Ich is offline
#4
Mar19-09, 03:09 PM
Sci Advisor
P: 1,883
Your points a and b are essetially true, as far as we know. I'm not sure about point c, but I think that black holes will evaporate before they all merge into a single, giant black hole.
Whatever, after the last black hole has been created, it will evaporate sloooowly, and that's it. No new universe - again, as far as we know.
m36bayarea
#5
Mar19-09, 10:36 PM
P: 12
Hawking radiation from black holes are very tiny compared to adding more mass and more particles falling into it. blackholes keep getting bigger as galaxies expand and universe expand. as galaxies getting farther apart and their mass increased proportionally then galaxies will reach a balance point where matter is no longer created and therefore, start shrinking slowly to a point where a big crunch of galaxies into their core black hole, each galaxy will form singularities and those singularities willl follow with big bang and new universes created as a result. one universe divided into millions, each galaxy now is a universe.
Dmitry67
Dmitry67 is offline
#6
Mar20-09, 01:20 AM
Dmitry67's Avatar
P: 2,456
Note that super-massive black holes will NEVER evaporate: their radiation will be less intensive then the incoming flow of the thermal radiation from the cosmological horizon (about 10^-33K)
m36bayarea
#7
Mar20-09, 02:24 AM
P: 12
e=mc*2 tells it all. neither energy nor matter can be destroyed.they just change form infinitely,therefore, universe will divide eventually as galaxies spread too far. and eventually each galaxy will shrink due to gravititional pull of their black holes and big crunch to follow in each galaxy separately. currently there is millions of galaxies in our universe. that means due to expansion of universe at very fast rate there will be millions of big crunch then millions of big bangs and millions of independent universe at the end. there maybe infinite number of universes now and we are just adding more to it since matter cant be destroyed and it keeps growing forever non-stop
Dmitry67
Dmitry67 is offline
#8
Mar20-09, 03:38 AM
Dmitry67's Avatar
P: 2,456
I would say, 60% of the above is correct
1. There are some problems when energy conservation laws are applied to the whole Universe. For example, when Unierse size *10, the volume increases by 1000, and the density of matter decreases by the factor of 1000. But (surprise!) the density of radiation decreases by 10000: the density of photons decreases by 1000 plus each photon becomes 10 times 'redder' -> 10 times less energy. You you check this, there are many articles about GR and eneryg conseration in it.
2. Yes, some matter can fall in the black holes inside the galaxies. Other matter simply evaporates into space in different forms (light, neutrinos, gas, isolated stars) and become too far from the black holes to be consumed.
3. Finally, big bang inside a blach hole is a pure speculation
TalonD
TalonD is offline
#9
Mar20-09, 10:14 AM
P: 177
the black holes, given enough time will simply evaporate due to hawking radiation untill eventually nothing will exist.
m36bayarea
#10
Mar20-09, 01:30 PM
P: 12
only small size blackholes evaporate thru billions of yrs. massive giant black holes at center of galaxies will never evaporate. they will feed on stars and other particles and eventually blackholes gravitational pull cause big crunch in every galaxy. universe will divide as a result and there will be only massive black holes left at the end. and eventually these black holes will cause a big bang due to extensive energy stored in singularity. each big bang will create a new universe and independent of each other without any gravitational attraction to eachother. there maybe infinite number of universes and it will keep adding on and on non-stop. E=mc*2 proofs that nothing is destroyed matter changes to energy in black holes then energy explodes and creates new matters. cycle will go on forever. it is called oscillating universe. repeats itself but in different sizes due to division. just think of one tree can create 100s of similar trees due to expansion of their seeds by rain washing their seeds and growing further away from original tree.
TalonD
TalonD is offline
#11
Mar20-09, 06:18 PM
P: 177
Quote Quote by m36bayarea View Post
Do you have a mathematical framework to support that view? Somehow I suspect not.
but then e=mc2 proofs it.....
actually... isn't it one of Newtons laws that proofs that nothing can be destroyed?
hmmm....
m36bayarea
#12
Mar20-09, 09:36 PM
P: 12
do the math and proof is there in einstein equations, that nothing can be destroyed . it just change form. energy converts to mass and mass converts to energy forever. oscillating universe. But our universe expanded so rapidly recently and our galaxies too far apart that it cant be stopped now. universe will continue to expand and galaxies drift apart until we wont be able to see light coming from other galaxies. eventually when galaxies are far apart then these galaxies will become independent of eachother. once that happens then giant blackholes of each galaxy will pull back stars and win over dark energy, blackholes will become larger and larger as it pulls stars toward it. once it is super super giant blackhole then a big crunch will happen in every galaxy independently. and what is left of universe are millions of massive giant blackholes far far apart. these super giant massive blackhole will be too far to attract eachother and gravity will have no efffect on one another. super massive blackholes will eventually explode due to stored energy from matters that fallen into it and cause a big bang and create a new universe. we have millions of galaxies so we will have millions of new born universes independent of one another. life will form again after billions of yrs and then die back after billions of yrs and all-over again. this process will go on forever. since nothing can be destroyed not even information. all information will come back to next generation of universes and so on forever. it will repeat itself at different space and time forever.
TalonD
TalonD is offline
#13
Mar21-09, 03:05 PM
P: 177
That is some interesting speculation !
Dmitry67
Dmitry67 is offline
#14
Mar21-09, 03:15 PM
Dmitry67's Avatar
P: 2,456
Black holes can not "eventually explode"
It is a total BS until you defined EXACTLY what doyou mean by it.
Hint:thay can not explode to the outer space. If you are talking about the singualrity, then it had already happened... well, its more difficult, the inner regions of BH are in another flow of time, so 'now' is not applicable to what happens inside.
m36bayarea
#15
Mar22-09, 01:11 AM
P: 12
Matter falling in blackholes converted to energy and is compacted densely. this energy neither escapes nor evaporates due to enormous BH gravitational pull that not even information can escape. Once entire matter of a galaxy or galaxies fallen into central BH. then BH with enormous pressure can not hold energy no longer since no matter to exert outer forces to BH to hold it from bursting. then BH will perform a big bang and in matter of seconds its entire energy burst into billions of light yr space and form new universe. stephen hawking proved this theory. refer to his calculations about origin of big bang. Big bang was originated from BH.
Dmitry67
Dmitry67 is offline
#16
Mar22-09, 02:07 AM
Dmitry67's Avatar
P: 2,456
1. Contre-intuitively, in GR enormous pressure *increases* the gravitation and make the 'explosion' more difficult
2. We dont have a theory of singularity (we need to wait for superstrings/quantum loop gravity) so we even dont know if 'pressure' is applicable to the singularity
3. Finally, no matter how pressure is high it can not push matter outside the black hole: I suspect you think that pressure can somehow 'overcome' gravity when it is strong. No, it can not: the spacetime is organized the way so 'future' for all objects inside the horizon is in the singularity. So any 'eventually in the future' for anything inside the horizon is in the singularity and never outside!
m36bayarea
#17
Mar22-09, 12:58 PM
P: 12
universe is balanced, stars pull on black holes and black holes pull on stars and balances the space time and everything is intact without falling apart. But all stars fall into BH due to BH gravity win. Then there is a vacuum outside BH. And BH exert Gravity force to space time without counter force , therefore, BH causes a big bang and in matter of one second creates new universe and new stars. BH is a storage facility for galaxies it stores entire data and info and total energy that fallen into it. According to einstein equation nothing can be destroyed. everything changes form from matter to energy then from energy to matter always forever. We have an oscilating universe where it repeat itself at different time and space, remember information never gets destroyed so if you are john doe genetic code today expect coming back in the next universe under same dna and roots. only change will be space time. for example if you live in america today then there is possibility you may be in germany or different location in future universe. space time does not remain same. but your genetic code and family roots remain the same
Dmitry67
Dmitry67 is offline
#18
Mar22-09, 01:54 PM
Dmitry67's Avatar
P: 2,456
What a meaningless spagetti of modern concepts :)
Register to reply
Related Discussions
Dividing by 0 General Math 23
Dividing by 1 is impossible General Discussion 21
Dividing Functions General Math 3
Dividing by zero General Math 6
Dividing 0 by 0 General Discussion 6
