Convergence and divergence help
The problem involves determining the convergence or divergence of the series \(\sum\frac{n^{n}}{(n+1)^{(n+1)}}\) as \(n\) approaches infinity. The subject area pertains to series convergence tests, specifically the Comparison Test and Ratio Test.
  • Participants discuss the application of the Ratio Test, noting that it may yield an inconclusive result. There is also mention of the Comparison Test and attempts to manipulate the series for analysis. Some participants suggest using the limit \((1+1/n)^n = e\) in their reasoning.
The discussion is ongoing, with participants sharing their attempts and reasoning. Some have provided suggestions for approaches, while others have confirmed the inconclusiveness of the Ratio Test. There is a focus on exploring different methods to analyze the series.
Participants are working within the constraints of the homework guidelines, which limit the methods available for solving the problem. There is an emphasis on using only the techniques covered in their coursework up to this point.
kidsmoker
Determine whether the following converges or diverges:
[tex]\sum\frac{n^{n}}{(n+1)^{(n+1)}}[/tex]
with the sum going from n=1 to n=infinity.
Comparison Test, Ratio Test.
This should be do-able with the above two tests, since those are the only ones covered in the book up to this point. I think it diverges but I can't seem to get anywhere with either test. Any help appreciated!
I think you are going to want to use the ratio test... try setting it up this way...
[tex]\lim_{n\rightarrow\infty} \frac{\frac{(n+1)^{n+1}}{((n+1)+1)^{((n+1)+1)}}}{\frac{n^n}{(n+1)^{(n+1)}}}[/tex]
You can try that. But it's going to give you a limit of 1. So the test is inconclusive. What you really need to do is find a way to use the famous limit (1+1/n)^n=e.
The ratio test is inconclusive (check for yourself using randomlogic's setup); why don't you show us what you've tried for the comparison test?
Indeed it is inconclusive.
Reasonable suggestion, nonetheless.
Okay thanks, I think i got it:
[tex]\frac{n^{n}}{(n+1)^{n+1}} = \frac{1}{(n+1)}(\frac{n}{n+1})^{n} = \frac{1}{(n+1)}\frac{1}{(\frac{n+1}{n})^{n}} = \frac{1}{(n+1)}\frac{1}{(1+\frac{1}{n})^{n}}} \geq \frac{1}{(n+1)}\frac{1}{(e+1)}[/tex]
using the fact that (1+1/n)^n tends to e.
Now [tex]\frac{1}{e+1}\sum{\frac{1}{n+1}}[/tex] diverges, therefore our series must diverge too :-)
Does that seem okay?
That's it. (1+1/n)^n is actually <=e, isn't it? But there's nothing wrong with playing it safe and saying <=(e+1) either.
  • · Replies 17 ·
