Structures. column theory, Buckling
The discussion centers on calculating the maximum length of a fixed-fixed rectangular steel bar subjected to a concentric load of 13,000 lbf, using the modulus of elasticity of 29 x 10^6 lbf/in². The correct moment of inertia for the rectangular cross-section must be used, specifically about its weakest axis. The buckling formula applied should include the squared value of the effective length factor (K), which is 0.5 for fixed-fixed conditions. The initial calculation of 81.3365 inches was incorrect due to misapplication of the moment of inertia and buckling formula.
  • Understanding of Euler's buckling theory
  • Knowledge of moment of inertia calculations for rectangular cross-sections
  • Familiarity with fixed-fixed column boundary conditions
  • Proficiency in using the buckling load formula Pcr = (I*E*(π)^2)/(K*L^2)
  • Review the derivation of the moment of inertia for rectangular sections
  • Study the implications of different boundary conditions on buckling behavior
  • Learn about the critical load calculations for various column configurations
  • Explore advanced topics in structural stability analysis
Structural engineers, mechanical engineers, and students studying stability in structural mechanics will benefit from this discussion.
jahoony
the question is in the picture.
the rectangular steel bar shown supports a concentric load of 13000lbf. Both ends are fixed. If te modulus of elasticity is 29x10^6 lbf/in^2, what is the maximum length the rod can be without experiencing buckling failure?
what I got was 81.3365. but I am not sure.
moment of inertia I got .1953125 from the cross section and just used Pcr = (I*E*(pie)^2)/(K*L^2) used .65 for K coz its fixed fixed.
Your calculation for the moment of inertia is incorrect. I don't know what formula you used, but you should use the Moment of Inertia of a rectangular bar about its weakest axis. Also, your buckling formula is incorrect, the K neeeds to be squared also, and K (ideal case) is 0.5 for a fixed-fixed column.
  • · Replies 47 ·
28K
10K
