Welding Detached Retinas with Lasers: Solving the Puzzle
The discussion revolves around a physics problem related to the energy output of a laser used for welding detached retinas. The problem involves calculating the energy deposited per pulse and determining the number of photons in each pulse based on given parameters such as wavelength, pulse duration, and average power output.
  • Participants explore how to calculate energy using the formula E=Pt and question how to derive the number of photons from the total energy and energy per photon. Some express uncertainty about the calculations involved, while others attempt to clarify the relationships between energy, power, and photon count.
Some participants have provided guidance on the calculations, while others express a lack of familiarity with the necessary equations. The discussion includes attempts to break down the problem and explore different aspects of the calculations, indicating a mix of understanding and confusion among participants.
There is mention of a lack of prior knowledge regarding the specific calculations needed, and one participant suggests consulting a medical professional or expert for more accurate information, highlighting the complexity of the topic.
wikidrox
I do not know how to do the second part of this question. I never learned this.
A laser used to weld detached retinas puts out pulses of 640 nm light, 25 ms long, which average 0.50 W output during a pulse.
i) how much energy can be deposited pre pulse?
ii) If the energy of a light particle (photon) is about 3 * 10^-19 J, how many photons does each pulse contain?
I do not know how to get this.
If you have the energy from the first part (E=Pt), and you know how much energy is in each photon, you just have to figure out how many photons give you that energy.
Etotal=N * Ephoton
No problem, let's break it down together.
i) To calculate the energy deposited per pulse, we can use the formula E= P*t, where E is energy (in joules), P is power (in watts), and t is time (in seconds). Plugging in the given values, we get E = (0.50 W)(0.025 s) = 0.0125 J. Therefore, the laser deposits 0.0125 J of energy per pulse.
ii) To calculate the number of photons, we can use the formula E= nhv, where E is energy (in joules), n is the number of photons, h is Planck's constant (6.626 x 10^-34 J*s), and v is the frequency (in Hz). We can rearrange this formula to solve for n: n = E/(hv). Plugging in the values for E and v (remember, frequency = speed of light/wavelength), we get n = (0.0125 J)/[(6.626 x 10^-34 J*s)(3 x 10^8 m/s)/(640 x 10^-9 m)] = 3.02 x 10^16 photons.
I hope this helps! Let me know if you have any further questions.
Unfortunately, I am not familiar with the specific calculations and equations necessary to answer this question. It would be best to consult a medical professional or an expert in laser technology for a more accurate response.
