Finding max/min given contraint
  • Thread starter Thread starter ultra100
The problem involves finding the maximum and minimum values of the function f(x, y) = xy constrained by the ellipse defined by (x^2)(1/9) + y^2 = 2.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss using Lagrange multipliers to find critical points and set up equations based on partial derivatives. Some participants explore alternative methods, such as rewriting the constraint to express y in terms of x.
There is an ongoing exploration of different approaches to solving the problem, with some participants sharing their findings and others seeking clarification on specific steps and equations used in the process.
Participants question the correctness of the results obtained and the methods used, indicating a lack of consensus on the approach to take. There is mention of using calculus techniques and tools like Maple for computation.
ultra100
Find the product of the maximum and minimum values of the function f(x, y) = xy
on the ellipse (x^2)(1/9) + y^2 = 2
I tried soving using lagrange multiplier and got:
fx = y - (2/9)(x*lambda)
fy = x - 2y*lambda
flambda = (x^2)(1/9) + y^2 - 2
then I set these = 0, but my answer came out wrong.. any suggestions for figuring out the min/max?
For y I'm getting, [tex]y = \pm 1[/tex]
The way I set this up was as follows:
Define:
[tex]f(x,y) = xy; g(x,y) = \frac{x^{2}}{9} + y^{2} = 2 \Rightarrow h(x,y,\lambda) = f(x,y) + \lambda g(x,y)[/tex]
(Note that the sign in front of [tex]\lambda[/tex] does not matter)
So let's take our partials, we get:
[tex]\frac{dh}{dx} = y + \frac{2 \lambda}{9}x, \frac{dh}{dy} = x + 2 \lambda y, \frac{dh}{d\lambda} = \frac{x^2}{9} +y^2 - 2[/tex]
We know that each of those partials vanish i.e. we can set each to 0.
The first one gives us
[tex]9y = -2 \lambda x[/tex]
and the second one gives us
[tex]\frac{x}{y} = -2 \lambda[/tex]
And by simple substitution we get:
[tex]9y^{2} = x^{2}[/tex]
So let's substitute it into our 3rd equation to get:
[tex]y^{2} + y^{2} = 2[/tex]
Which yields our desired result of [tex]y = \pm 1[/tex]. Now we can plug this into our g(x,y) to get [tex]x = \pm 3[/tex]
Note that it doesn't matter which value for y we pick therefore our solution set will be:
[tex](1,3), (1,-3), (-1,3), (-1,-3)[/tex]
Now if you don't want to do this using Lagrange Multipliers, we can just realize that we can rewrite our g(x,y) as
[tex]y = \pm \sqrt{2 - \frac{x^2}{9}}[/tex]
and now we can substitute this into our f(x,y) get an equation of one variable i.e.
[tex]\bar{f}(x) = \pm x \cdot \sqrt{2 - \frac{x^2}{9}}[/tex]
Now we can proceed using the techniques you learned in Calculus 1 (I'm going to use Maple because I'm lazy)
> a:=x*sqrt(2-x^2/9);
a := [tex]\frac{1}{3} x \sqrt{18 - x}[/tex]
> solve(diff(a,x)=0,x);
-3, 3
Note that choosing the negative root produces the same results.
what equations are you using to get y = to +/- 1?
Refresh your page :)
Thanks! This helps a lot
  • · Replies 36 ·
