Register to reply
Magnetic field on current loop, involves rotational energy
Share this thread:
cdingdong
#1
Dec16-08, 12:11 AM
P: 3
A rectangular loop of sides a = 0.3 cm and b = 0.8 cm pivots without friction about a fixed axis (z-axis) that coincides with its left end (see figure). The net current in the loop is I = 3.2 A. A spatially uniform magnetic field with B = 0.005 T points in the +y-direction. The loop initially makes an angle q = 35 with respect to the x-z plane.
The moment of inertia of the loop about its axis of rotation (left end) is J = 2.9 10-6 kg m2. If the loop is released from rest at q = 35, calculate its angular velocity [tex]\omega[/tex] at q = 0.
2. Relevant equations
this is kinetic energy:
KE = 1/2I[tex]\omega^{2}[/tex] but moment of inertia is specified to be J, so
KE = 1/2J[tex]\omega^{2}[/tex]
this is potential energy for a loop with current and magnetic field acting on it:
PE = [tex]\mu[/tex]Bcos[tex]\theta[/tex]
moment vector [tex]\mu[/tex] = NIA where N = number of loops, I = current, A = area, B = magnetic field
so, PE = NIABcos[tex]\theta[/tex]
3. The attempt at a solution
I recognize that the angular kinetic energy equation can be used to find the angular velocity. KE = 1/2J[tex]\omega^{2}[/tex].
Final kinetic energy = initial potential energy. Initial potential energy = NIABcos[tex]\theta[/tex]. so, we could say
1/2J[tex]\omega^{2}[/tex] = NIABcos[tex]\theta[/tex]
the right side is potential energy. that equals
N = 1 turn; I = 3.2 Amps; A = 0.003*0.008 = 2.5e-5 meters; B = 0.005 Teslas; [tex]\theta[/tex] = 35 degrees
(1)(3.2)(2.5e-5)(0.005)cos(35) = 3.276608177 * 10^-7 Joules. we'll call this 3.2766e-7
so, now we have
1/2J[tex]\omega^{2}[/tex] = 3.2766e-7
J = 2.9 10-6 kilogram meters squared. we'll call this 2.9e-6
1/2(2.9e-6)[tex]\omega^{2}[/tex] = 3.2766e-7
[tex]\omega[/tex] = [tex]\sqrt{(2*3.2766e-7)/2.9e-6}[/tex] = 4.753655581 * 10^-1
BUT, the answer happens to be what I did except that they did not take the square root at the end.
so, they got 2.259724138 * 10^-1.
did i do something wrong? what i did makes sense in my mind. is their answer wrong? why did they not not take a square root at the end? is kinetic energy not = 1/2J[tex]\omega^{2}[/tex], but instead 1/2J[tex]\omega[/tex] without the square?
i thank everybody in advance!
Phys.Org News Partner Science news on Phys.org
Scientists develop 'electronic nose' for rapid detection of C. diff infection
Why plants in the office make us more productive
Tesla Motors dealing as states play factory poker
Doc Al
#2
Dec17-08, 01:22 PM
Mentor
Doc Al's Avatar
P: 41,477
Quote Quote by cdingdong View Post
What's the final potential energy, when θ = 0?
cdingdong
#3
Dec17-08, 02:32 PM
P: 3
wow, now that you bring it up, i realize my mistake. you're right! i forgot the final potential energy. so, the answer works, but there is something that bothers me.
Ki + Ui = Kf + Uf
there is no initial kinetic energy because it came from rest, so that is zero
Ui = Kf + Uf
rearranging it,
Ui - Uf = Kf
NIABcos35 - NIABcos0 = 1/2J[tex]\omega^{2}[/tex]
NIAB(cos35 - cos0) = 1/2J[tex]\omega^{2}[/tex]
(1)(3.2)(2.5e-5)(0.005)(cos35 - cos0) = 1/2(2.9e-5)[tex]\omega^{2}[/tex]
-7.233918228 = 1/2(2.9e-5)[tex]\omega^{2}[/tex]
when i find the potential energy, initial PE - final PE, i get a negative number. so, when i set it equal to 1/2J[tex]\omega^{2}[/tex], i get a square root of a negative number, which is not possible. if i take the square root of the absolute value of that number, the answer is correct. is there something wrong with my signs?
Doc Al
#4
Dec17-08, 05:39 PM
Mentor
Doc Al's Avatar
P: 41,477
Yes, your signs are messed up. The correct expression for PE is PE = -IABcosθ (note the minus sign).
So Ui - Uf = (-IABcos35) - (-IABcos0) = IAB(cos0 - cos35).
cdingdong
#5
Dec18-08, 12:16 PM
P: 3
ahhhh, i see. well, that will solve my problem. thanks Doc Al!
Register to reply
Related Discussions
Magnetic field from rectangular current loop Introductory Physics Homework 9
Magnetic field/simple current loop Classical Physics 9
Interaction of a Current Loop with a Magnetic Field Introductory Physics Homework 2
Magnetic Field due to a current loop Introductory Physics Homework 4
Current loop + perpendicular current : magnetic field? Advanced Physics Homework 1
