Angular momentum/angular velocity.
  • Thread starter Thread starter the whizz
    Angular Velocity
The discussion focuses on calculating the final angular speed of a solid vertical cylinder after a piece of putty is dropped onto it. The cylinder has a mass of 10.0 kg and a radius of 1.00 m, initially rotating at 7.00 rad/s. The putty, weighing 0.250 kg, is dropped at a distance of 0.900 m from the center. The conservation of angular momentum is applied, utilizing the equations Lbefore = Lafter and L = Iω, where the moment of inertia is calculated using I = (1/2)MR² for the cylinder and I_f = (1/2)MR² + mr² for the final state.
  • Understanding of angular momentum and angular velocity concepts
  • Familiarity with the moment of inertia calculations
  • Knowledge of the parallel axis theorem
  • Basic algebra for solving equations
  • Study the conservation of angular momentum in closed systems
  • Learn about the parallel axis theorem in detail
  • Explore moment of inertia calculations for various shapes
  • Practice problems involving angular velocity and angular momentum
This discussion is beneficial for physics students, educators, and anyone interested in mechanics, particularly in understanding rotational dynamics and angular momentum calculations.
the whizz
1.A solid, vertical cylinder of mass 10.0 kg and radius 1.00 m rotates with an angular speed of 7.00 rad/s about a fixed vertical axis through its center. A .250 kg piece of putty is dropped vertically onto the cylinder at a point 0.900 m from the center of ration and sticks to the cylinder. Determine the final angular speed of the system.
Lbefore=Lafter
L=Iw
the angular momentum is L and the angular velocity is what i am looking for that is w.
I believe you can say that IoWo should = IW
I am unsure what you are to do with the mass of the putty and the center of radian issue.
I believe you need to set up taht W = (Io/I)wo
Io = MR^2?
[tex]I_{o}\times \omega_{o}=I_{f}\times \omega_{f}[/tex]
We know [tex]I_{o}= \frac{1}{2}MR^2[/tex] plus we know wf
[tex]I_{f}=\frac{1}{2}MR^2+mr^2[/tex]
Note: the [tex]I_{f}[/tex] changes, the parallel axis theorem is used.
only [tex]\omega_f[/tex] left that's unknown.
  • · Replies 17 ·
  • · Replies 71 ·
18K
