Thread Closed
Heat up water with low temperature steam
Share Thread Thread Tools
Dec18-08, 08:19 AM   #1
- Is it possible to heat up water from 50 °C to 100 °C with saturated steam of 30 °C?
- If my hand is at 37 °C, is this 30 °C steam hot or cold when I touch it?
2. Relevant equations
Steam tables.
3. The attempt at a solution
I'm a bit confused here because there are two ways to see it.
Condensing of steam transfers heat. But temperature difference also transfers heat.
But I'm guessing that the statement is not possible. I think the steam would just stay steam and not form condensate because it would have to release heat to my hand. That wouldn't be possible if my hand is hotter than the steam?
Edit: oh wait, I just realized something. When my hand is at 37 °C, I would just superheat the steam to 37 °C... or my hand would cool off to 30 °C and suddenly when my hand would become 29 °C because of the surrounding cold air I would feel a surge of hot warmth to my hand and it will be kept at 30 °C.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Bird's playlist could signal mental strengths and weaknesses
>> Minus environment, patterns still emerge: Computational study tracks E. coli cells' regulatory mechanisms
>> Bacterium uses natural 'thermometer' to trigger diarrheal disease, scientists find
Dec18-08, 06:52 PM   #2
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Consider what pressure water is at when it is saturated at a temperature of 30 C. Can you find that pressure from the steam tables? It should be ~4.25 kPa (absolute pressure).
Right. If the steam really is saturated at 30 C, the pressure is very low and your hand at 37 C would cool while the steam would superheat.
Dec19-08, 12:40 AM   #3
I didn't search up this pressure.
So it's 0.04 bara, I have a feeling that it's very low. At our plant we have vacuum at 0.2 bara. So basically we would strip out all energy of the water so there is less energy in that steam of 30 °C.
BUT!: The condensing heat is still very high! So if my hand was at 10 degrees, we wouldn't need much steam to heat up my hand.
Thread Closed
Thread Tools
Similar Threads for: Heat up water with low temperature steam
Thread Forum Replies
steam/water General Physics 17
Heat and Internal Energy and Heat and Temperature Change: Specific Heat Capacity Advanced Physics Homework 4
water to steam General Physics 3
Water into steam Introductory Physics Homework 0
can the water (100 oC) gain latent heat energy from the same temperature object? General Physics 2
