Deriving Electric Field Independence on Negligible Separation
The electric field between two parallel plates is independent of the separation distance when the separation is negligibly small, as derived using Gauss's Law. By applying Gauss's Law to a sheet of charge, it is established that the electric field is perpendicular to the surface and uniform across the plates. The total electric field between the plates is the sum of the fields from each plate, reinforcing the concept that the field remains constant regardless of distance due to the infinite nature of the plates.
  • Understanding of Gauss's Law
  • Familiarity with electric fields and charge distributions
  • Knowledge of symmetry in electrostatics
  • Concept of infinite planes in physics
  • Study the application of Gauss's Law in different geometries
  • Explore the concept of electric fields from infinite sheets of charge
  • Learn about the behavior of electric fields in capacitor systems
  • Investigate the implications of electric field independence in practical applications
Physics students, electrical engineers, and anyone interested in electrostatics and the behavior of electric fields in various configurations.
spikelau
I read from a website that the electric field is independent of the separation between the plates if the separation is negligibly small. But how to derive this?
Use Gauss's Law
Start by deriving the field close to a sheet of charge. Use Gauss's law, realizing that the electric field, by symmetry, will be perpendicular to the surface.
The field between two parallel plates will be the sum of the fields from each plate.
In fact, this is true for a single, infinitely large plane too. And a hand waving argument for why this might be true is that there is no distance scale set by an infinite plane ...i.e. the result should be scale independent. I could use this same argument for a single point charge, or a line charge too...and of course it would be wrong, so don't take it too seriously
But go ahead with the Gaussian pillbox and see what you get.
  • · Replies 32 ·
